Question about Baby Gear
Angel care movement and sound!! There's no sound coming from parents unit. The second green light on the nursery unit flashes. What to ddo to get it to work
4 Suggested Answers
  • 7 Answers
SOURCE: Both units are switched on but the parents' unit
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
the parent unit waits for the signal then pairs.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
Posted on Jun 07, 2010
Testimonial: "it worked :)"
SOURCE: I request information about angel care AC401 We
press and hold the little round blue light at the top for about 5 second until it beeps.
Posted on Feb 10, 2011
SOURCE: I got 1 parent unit and 1 nursery unit of Angel
hi,
please tell me how to pair AC1100 the nursery and parent units
please for help..
best regards to all
Posted on Jul 04, 2012
How to pair AngelCare AC1100 the nursery and parent unit?
Hi
We would recommend contacting Angelcare UK Customer Care on 0845 009 1789
Jul 04, 2012 | Angelcare Baby Care
On one of our two parent receivers, it's showing 1 red light with 4 green lights above it. No sound at all. The other parent receiver works just fine, perfectly clear. I think my toddler was playing...
I had the same thing happen to one of my parent units over the weekend. The issue is that the parent unit lost the pairing with the nursery unit. Once I re-paired them, it's working great again. This is in the Troubleshooting part of the manual, but I've copied below for your convenience.
If Parent Unit won't lock onto the Nursery Unit, or you purchased a new Nursery Unit, follow the procedure below to pair the Parent Unit and Nursery Unit. If you purchased a new Parent Unit, skip Step 1. The new Parent Unit is ready to pair with your Nursery Unit.
1. Erase the Pairing from the Parent Unit. Turn the Parent Unit off. Hold the Volume Down Button on the Parent Unit while pressing the On/Off Button. Continue to hold the Volume Down Button until you hear a single beep and all of the Sound Lights illuminate briefly. Release the Volume Down Button. Press and hold the Volume Down Button again. Within 2 seconds you will hear a beep. Release the Volume Down Button. All of the SoundLights and the red Loss Connection LED will be lit. The Parent Unit is ready to pair with Nursery Unit. 2. Pair the Parent Unit with Nursery. Place Nursery Unit in the same room, five (5) feet (1.5 meters) away from the Parent Unit. Turn on Nursery Unit using the On/Off Button on the side. The green power light should come on. Within a few seconds, the Parent Unit will find the Nursery Unit. The SoundLights will shut off and the Parent Unit will beep. The Parent Unit is now paired with Nursery Unit. 3. Repeat this procedure if you need to pair another Parent Unit with the Nursery Unit.
Nothing happened when I turned on the Nursery Unit. What do I do? First try turning the Nursery Unit off, and then on again. If the Parent Unit still does not pair with the Nursery Unit, press the Channel Button on the Nursery Unit, then turn the Nursery Unit off, and then on again.
Hope this helps.
Feb 07, 2011 | Graco iMonitor Vibe Baby Monitor 2M16
I request information about angel care AC401 We have build this product but we are not able to work it. When we turn on the unit parent the digital screen shown "--" and the nursery unit icon...
Nov 08, 2010 | Angelcare Baby Movement and Sound Monitor...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
Angle care wont connect to the base
Manuals: http://www.angelcare-monitor.com/Canada/en/help
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Dec 20, 2009 | Angelcare 2009 Movement Sensor Baby...
I droped the monitor last night and I only get to dashes appearing on the screen and it wont pick up any sound!
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Nov 26, 2009 | Angelcare Deluxe Movement Sensor & Sound...
My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu.
Oct 16, 2009 | Angelcare Deluxe Movement Sensor & Sound...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
Baby Gear Logo
190 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
