Question about Dishwashers
Why does the base tray of my Nardi dishwasher LS160HL collapse when loaded or when I slide it into the machine?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my daughter fell into the
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Apr 20, 2011
My machine seems to be stuck on a drain cycle
Sounds like your 'anti flood' system is activated. This happens when a leak fills the drip tray on the base of the machine, and a anti flood float switch senses water in the tray. Leaks can come from several sources - loose pipes, leaking door gaskets - even opening the door while the machine is hot! i.e. to add an extra item after the machine has started, for example. ISOLATE THE POWER and examine the base tray, if its a free standing machine tip the machine back at an angle (The Hemlich manoeuvre for Dishwashers lol) and the water will flood out - if built in, remove the lower front panel. Once the water is removed, the machine should start - but if the problem occurs, the leak is still there. Zanussi machines are tricky - you'll probably need an engineer to sort it out - expect not much change out of £100. Cheers!
Oct 16, 2015 | Zanussi 18 in. DCS12W Free-standing...
Whirlpool adp 951
I have nardi dishwasher model LSFHLX IT SHOW E2 error after completing the programe what problem plz help
Dec 15, 2013 | Dishwashers
My daughter fell into the dishwasher while we were loading it and the door springs are bent. When you pull out the bottom tray to load or unload the dishwasher the door bends so far down that the tray...
heatman101
Apr 20, 2011 | Dishwashers
Eco light comes on when I switch on machine but can't change programme and it doesn't work some water still under filter
This indicates water in the base, there is a polystyrene float that operates a cut off switch if water leaks into the base, this could be caused by a leaking pipe connection, or simply by water getting by the door seal and eventually having enough volume in the base te operte the float switch, try tilting the machine backwards if water comes out of the basethen this should cure the problem, but if it recurs fairley quickly you should have the hose connections checked for tightness, can be accessed from the base.
the dishwasher should be isolated from the supply first base tray is secured by 6 screws, the float switch is attached to the base so care should be taken when removing the base tray
Apr 23, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Machine sliding off its base...
yu need to make sure you have alevel and firm base for the machine also the base should be secured to the machine
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
My built in dishwasher nardi door hook has broken
Contact Nardi Spares in Huddersfield Tel 0845 050 8558. They should be able to supply a replacement catch.
Nov 11, 2009 | KitchenAid 24 in. KUDP01FL Built-in...
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Bosch Dishwasher SHV4313GB/17 Wont switch off ! The machine keeps running even when you open the door The pump is trying to drain water away (even though there is no water left in machine ) Have tried to...
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills OK, then this ISN'T a solution to your problem. If your machine doesn't fill but your drain motor continues to hum for no apparent purpose, this may work.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Mar 08, 2008 | Dishwashers
Top Load GE washing Machine
Hello:
all you need to do first after unplugging the power lead, is to empty the drum from any left over water,,,, and tip the machine gently on one of its sides, on top of a clean sheet to prevent any scratches. now you have to unscrew the bottom tray if any! and you should be able to gain clear access to the main motor, which will be linked to the main agitator shaft/poly with a V belt .
if you have reached this point OK !
physically check the belt for any wear and tear and if needs to replace it , and if not ( BUT LOOSE) check on the main motor base where you should find four sliding slots held to the machine body by some bolts or nuts !!!, if so loosen those bolts and gently pry the motor outwards to tighten the V belt.
make sure that it should have some End play in it(ie not very tight).
when done tighten the motor base bolts again, , put the base tray back and screwed ,,,,, re start the machine and give it a try!
good luck.
cheers.
Jan 31, 2008 | Washing Machines
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
