Question about Car Audio & Video
CD stuck in player
CD is stuck in the unit.When I switch to CD mode it says CD eject. When I push eject nothing happens.
KaeZoo
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
SparkGap
  • 363 Answers
SOURCE: cd ejects
There is a varety of causes of ejection of a CD in any player. If the ejection is immediate it may be:- Incorrect length fixing screws fouling mechanism. Faulty eject button Fauly mechanism position sensor/switch Misaligned mechanism Causes of ejection after the disc spins up:- Disc upside-down Incorrect format i.e MP3 data disc in standard CD player Incompatible CD-R type Badly scratched disc Warped disc Player out of calibration Hope this helps
Posted on Sep 21, 2007
SOURCE: cd player won't eject cd what do i do
too come out
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Posted on Jul 03, 2008
  • 40 Answers
SOURCE: cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Posted on Sep 16, 2008
Jammed cd player
one response I read for this was to use a pencil in the slot and pushed something inside the cd player and it unjammed and the unit started to work again
Mar 20, 2014 | 2002 Honda Accord
Cd player will not eject
A common failure of magazine-type CD changers is that a CD gets stuck in transit between the magazine and the player mechanism. It may be necessary to remove the unit and disassemlbe it to solve the problem.
Mar 06, 2014 | Land Rover Cars & Trucks
Alpine IVA-D310 will not eject CD. If you push eject button you hear the machine trying to eject CD, but nothing happens. The display says eject malfunction.
If you are comfortable with taking the unit out and taking the back off of it, you can access the CD that is stuck. If you are not comfortable in doing this, then I would recommend taking it to an electronics shop where they can work on it.
Mar 05, 2011 | Alpine IVA-D310 Car DVD Player
My CD is stuck in the CD player. It will play, but it won't eject. When I hit the eject button, it makes noise, but nothing happens.
Sometimes there is a small hole in the front panel, you may push a paperclip straight into the hole and it will eject the tray manually. If there is no hole than the unit has to be removed and opened to gain acsess. The reason for the failure is belt wear. Thank you, Dana
Feb 16, 2010 | 2004 Jeep Grand Cherokee
My cd player will not eject the disks
i've had the same problem.... push eject and either nothing happens or "CD Error" appears... the only solution i have found is gentle trying to insert another cd (usually one that's already scratched and worthless... just in case) and usually the stuck cd will eject. not an expert... but it works
Feb 01, 2010 | 2000 Volvo S80
CD won't eject from 05 Murano
You will have to remove the player and disassemble it to retrieve the stuck CD.
Aug 11, 2017 | 2005 Nissan Murano
Cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
Jun 13, 2009 | 2005 Nissan Altima
I have a 2006 Nissan Xterra with a Rockford Fosgate
if is there a warped CD in the tray
pull the unit apart
or a major fail .. easiest fix is
source a used Rockford Fosgate 6 CD player that works
plug that in
ebay / inline or wrecker 2006 Nissan Xterra Rockford Fosgate AM FM Radio 6 Disc CD Player PN...
Mar 21, 2017 | Rockford Fosgate Car Audio & Video
CD stuck in player
Both times that a cd has become stuck in the player I simultaneously pushed the power and eject buttons. I came across this solution in the owner's manual and it worked perfectly both times I have had to do it.
Sep 20, 2007 | JVC KD-G200 CD Player
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
