Question about Panasonic Televison & Video
Panasonic CX DP880N error E1 How do I clean the laser lens?
No matter what discs I put in I get the dirty disc error code. I assume it means the laser lens is dirty . How do I get access to clean it?
  • 156 Answers
Usually the problem is a stray hair. I would try blowing into the compartment with a soft drink straw while moving the straw around. Be careful NOT to spit through the straw!
Posted on Apr 03, 2015
My ps3game console will not take games
If you mean it won't load from a game disc I've had this problem with mine. It was an older ps3 with a lot of hours on it. I would clean the laser lens with a q-tip and rubbing alcohol. When the lens gets too dirty it can't read the disc. I tried laser lens cleaning discs (I know they recommend not using them or touching the laser lens for that matter) they worked a couple of times but usually wouldn't. I had to disassemble my old 80gb or actually just open the case unplug 2 connections from the disc player and remove it. Then take the metal case off the disc player. DO NOT pop the disc player completely apart! The plastic gears in the drive and ejection system have to be in time. Not quite so easy to fix. With the metal case removed you can reach the lens or lenses (there are 2 one is for blue ray I believe) with a cotton swab dipped in rubbing alcohol to clean it. This worked for me at least a dozen times if not 2 dozen.
Nov 29, 2014 | Sony Playstation 3 (PS3) Console
How do you clean the laser please
You will probably have to disassemble the changer to access the laser lens. You can clean the lens with q-tips and rubbing alcohol. Be sure to be very gentle or you can scratch the lens which will ruin the lens.
Dec 29, 2011 | Panasonic CX-DP610 6-Disc CD Changer
Ps3 slim error code 8001002b what could this code be.
The code means "dirty or damaged disc". The PS3 has encountered some kind of problem reading the disc.
Possibly the laser could be having problems, possibly the disc.
Try another game disc. If it works, the game disc you are trying to start is somehow damaged.
If it doesn't, the laser most likely has a problem.
If the laser is the problem you can try and clean it with a DVD laser lens cleaner like this one :
http://www.walmart.com/ip/Innovera-CD-DVD-Laser-Lens-Cleaner/14915544
Regards
Sep 28, 2011 | Sony Playstation 3 (PS3) Console
Disc spins for about 30 secs then error reads wrong disc, I have 2 players, both same fault
was the player reading discs before now? And how long have you been using this player?
I suspect that the laser (lens) of this player is weak, that's why it cannot load discs.
The symptoms is like that of a dirty or bad laser (lens).
Use a lens lens cleaner to clean the lens. But if that doesn't solve the problem, then it means you will have to replace the lens of your player completely, in order for it to play/read discs again.
Good luck.
Aug 25, 2010 | Car Audio & Video
Disc error
how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play DVDs.
The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Toshiba SD-2815 Multi-disc DVD Player
Won't read disc
Common issues causing the dirty disc error are: dirty lenses, lasers wearing out over time, capacitors failing on the control board, grease on the rails the laser slides back and forth drying out, and using non pressed (burned) media that fades over time.
Sounds like you have tried cleaning the lens and I am assuming this is happening to all your media. So I would say that it probably needs to be replaced because lasers and other internals are not user serviceable. Especially when dvd players are so cheap now.
doesnt look like your alone by this post.
there are many lost cost options for replacement
Mar 23, 2009 | Sony DVP-NC615 Multi-disc DVD Player
Disc error
Assuming you've tried regular nonrecorded DVD discs, there are many things that can cause this:
Dirty or defective laser. (try a cleaning disc).
Disc not spinning.
Laser not moving on slide rail.
I would at least try cleaning the laser lens before giving up.
Hope that helps...
Geno
Mar 24, 2008 | Televison & Video
CD error
Usually the turning longer than usual means the laser is having a hard time reading the disc. See if the same disc will work in another cd player, if its not the disc try cleaning the lens with a lens cleaning disc. ER (error) usually means a> the disc is unreadable or b> the laser is dirty or inoperable
May 26, 2007 | JVC RC-BX33 Cassette/CD Boombox
No disk
Get a lens cleaning disc and try to clean the laser lens first. If that doesnt help, your going to need to have the unit serviced.
Sep 24, 2006 | Panasonic SC-HT75 System
PLayback of anything
If it occurs on a specific disk (one or more but with the same discs) Maybe the disc is dirty: Wipe it clean. Some DVDs are very sensitive.. Also make sure you inserted a disc the unit cannot play (see the list in the user guide p. 6 - http://www.fixya.com/BrowseManual.aspx?mnlid=7920&prdid=232136&__PAGED_=6 ) If not: The laser lens in your DVD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lens cleaning discs are available at many electronics retail store. Sorry I can't help you more. Good luck!
Dec 08, 2005 | Panasonic DVD-F65 Multi-disc DVD Player
Televison & Video Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
