Question about Whirlpool Refrigerators
Why in double door whirlpool 242 let's, bottom part is frozen, how to rectify
  • Whirlpool Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Posted on Apr 07, 2015
Whirlpool double door fridge. Door wont stay closed. Have to push extra hard to keep it closed
Take out the shelves and drawers. check the rear is clear of ice before putting them back in place, and ensure they are not stopping the door closing. Next check the top and bottom of the door. Is it hitting the frame when closing? If so, straighten it up by tapping the hinge side of the door to make it square to the frame.
Jul 04, 2015 | Whirlpool Refrigerators
How do I get the door I removed back on my 1964 Whirlpool double oven?
THERE ARE USUALY 2 LEVERS OR HOOKS ON THE BOTTOM OF THE DOOR THAT YOU NEED TO LINE UP WITH THE HOLES THAT ARE ON THE OVEN. YOU NEED TO LINE THEM UP AT AN ANGLE & NEEDS TO BE STRAIGHT TO SLIDE IN.
Jan 31, 2015 | Whirlpool RBD305PD Electric Double Oven
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
I have a whirlpool refrigerator model et1fttxcq08 and the ice maker works fine but the water dispenser will not. You hear the motor when you press on the dispense button but no water comes out.
you will need to check the water line inside the door and make sure there is no frozen water in the line.
To check and make sure the water valve is working you can disconnect the water hose on the bottom of the door make sure to have a glas or small pot handy, when the water line is disconnected you can try and dispence water and if water comes out then you have frozen water in the line in the door.
You can also use a long piece of weed eater line and sticke it through the water line in the door and it should go all the way through.
If no water comes out when you have it disconnected then the water may be frozen in the lines on the inside of the fridge.
If the water line in the door is frozen you can use a blow dryer and blow hot air in the tub alternating between the top and the bottom of the line this can take awhile to do but will clear it up.
Dec 24, 2010 | Whirlpool Refrigerators
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool double oven rb130pxv
As long as you line up the hinges with the receptacle in the door, it should slide right down. Try a shot of WD-40 on both.
Sep 08, 2007 | Whirlpool RBD305PD Electric Double Oven
Refrigerators Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
