I have a 12000btu TCL aircon. After about 3 minutes of running, the runlight starts flashing for 5 times and compressor switches off. I need to unplug the unit for about 2 minutes and restart.Same thing happens again.
KOakaKO
  • 135 Answers
SOURCE: "Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Posted on Aug 04, 2007
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Intermittant starts running crappy and tcl light comes on
When the TCL light is on usually means there's a problem with the traction control, need to have inspected real soon. Could be a speed sensor.
Nov 24, 2013 | 2004 Mitsubishi Diamante
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
I have an TCL aircon and it comes up with a message E2 and then switches it self off, the aircon is about 8 months old can someone help me with whats wrong with it please and thanks :)
TCL provide a 5 year warranty. i would suggest you contact the nearest Agent. An E2 error from what I remember is an overheat / overpressure problem. Check your filters on the indoor unit. If they are blocked, this error could appear and it wont be a warrantable fault...
Jul 14, 2011 | Turboair TAS-24H Split System Air...
TCL air conditioner works for about 15 minutes, switches off and gives a signal of 4 red flashes every now and then.
It's due to abnormality of out door unit. Clean condenser coil first. Check run amps. If gradually increases, replace running capacitor. Check rpm of f.motor. If slow, replace fan capacitor. If still problem, replace fan motor. Service indoor unit also. Thanks.
Feb 04, 2011 | Heating & Cooling
Samsung Cool Tech Dynamic not cooling properly
Alan if the power was off for less than 5 minutes the compressor high pressure went to the low side and the compressor just will not start. The thermal overload Klixon will click about every 8 or 9 minutes and the compressor will not start.
Unplug it for about 30 minutes and then plug it back to see if it lites off and runs correctly.
As for the control panel... (fingers crossed) hopefully it is a symtom of the compressor not starting. Again unplug it for 30 minues and restart it after that. It just may get things back to normal without any repair service.
Jan 23, 2010 | Refrigerators
Telefunken TAS 180E aircon unit, After startup the unit runs for
have 9000btu recently changed the compressor,cleaned the system,installed a drier,runs for 2days and start icing up on the
discharge,like it short of gas ,stop the unit for a while check the gas its shows 390kpa.what could be causing it not to work properly
Dec 31, 2009 | Heating & Cooling
My fedders aircon compressor does not turn on again whenever its thermostat turns it off. what i had to do is unplugged the power cord and turn it on again to work. i already replaced the capacitor. what i...
you have a time delay build in on the pc board of 3 minutes. If it takes longer than 3 minutes check your compressor overload protector, Maybe the compressor is overheating, check your coils for proper air flow. ultimately if the compressor checks ok then it's your board relay. also try testing the temperature sensor ( thermostat)
Oct 03, 2009 | Fedders A6X05F2D Air Conditioner
Aircon Compressor problem
Im not that familiar with cars, but if this is a new (90 or newer) then the RPM going so high is because the fast idle switch. It does this to compensate for the extra power being used by the compressor, which isn't coming on at first. Is the electric fan coming on for the condenser coil at the same time as the compressor? You should have 2 fans, one is for the radiator water, the other is for the A/C. There are temperature controlled sensors for these fans on some models. Its possible that may have something to do with it.
Mar 05, 2008 | Heating & Cooling
Aircon pipes dont fit
the refrig doods use out side diamiter. 1/2" pluming pipe is called 5/8" in refrig. we use a reducer to go 1/2 od to 3/4" od, or we swedge one to get the smaller to fit inside the larger and soder. add flairs to the finished size pipe
Feb 17, 2008 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
