Question about ACDelco 2001 to 2005 AC DELCO 6K815 Ford Taurus Serpentine Belt for V6 3.0L
Digham for putting belt back on after replacing the alterntor
Directions on how to put belt back on
Computer box
Your belt is stretched and not charging the system or your tensioner is bad or both.Here's a link to it,the part is number one on the picture,also watch belt as it turns and rev up and see, Repair Guides Charging System Alternator AutoZone com
Feb 28, 2014 | Ford Explorer Sport Trac Cars & Trucks
Voltage regulator
Alternator voltage regulator! Depending on the Alternator and model, it is either located inside of the alt (defective return it and replace) or it it mounted externally. remove and replace
Nov 09, 2013 | 2004 Ford Explorer Sport Trac
Which direction does the timing belt installs?
You know, I replaced alot of these and seen that on the directions. And yet they do not put a mark on the new belt. I have looked these things over and found know way to tell. So I just put them on. I have never had one come back. May I also recommend that since your already in there, that you replace all the timing components and the water pump too, if it's in there.You don' want to go back in a couple of months from now.
Nov 30, 2010 | 1991 Chrysler LeBaron
Need to replace the main belt on the bottom of the washer. The belt goes around the drive pulley directly below the electric motor which is accessible from the front bottom access panel. The belt goes...
Unplug the motor wiring, remove the bolts holding the motor bracket (4 I think) remove the hoses from the pump and lift the motor and pump out. Remove the 3 screws on the pump and separate from the motor. Put the belt on the pulley and replace the pump. Slide the motor and pump back in with the belt attached, but don't put the 4 bolts on until you put the belt over the tub pulley. Then put them in and plug the wiring back onto the motor. That should do it!
Nov 20, 2010 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
I need to replace the pulley that puts tension on the belt of a 93 ford f 150 with a 351 engine
Hi:
The basic process to change that pulley is to first loosen and remove the serpentine belt. Make a diagram on paper of the belt path, if there isn't one under the hood on a decal.This is done by putting either a wrench or ratchet on the tensioner, and rotating it away from the direction that it applies pressure to the belt. There is either a square hole to put a ratchet in, or a hex head to attach a wrench. Once you get the belt slipped back, examine the belt to see if it needs replaced. The tensioner assembly is held to the engine with a couple bolts, and can now be removed and replaced. Reinstall the new or old belt, and the last step is to rotate the new tensioner back and slip the last section of belt under it.
Jan 17, 2010 | 1993 Ford F150 SuperCab
Loosen pivot bolt and adjustment bolt and the alterntor still want come loosen.
It may be a bit corroded on the long bolt that is the pivot bolt. Just put a bar or large screwdriver between the alternator and the engine and pry it (making sure both bolts are plenty loose), or pry it toward the engine with whatever will give you leverage if you don't have the belt off. It will come, don't be afraid of it. If you make no progress let me know by comment.
This will work.
Dec 05, 2009 | 1993 Honda Accord
How to remove a alterntor
What motor do you have?? If 4.6 or 5l V8, 4 bolts 10mm will get it done. Take of serpantine belt first and battery cable
Nov 27, 2009 | 1997 Mercury Sable
How do I install a serpentine belt -
If your Engine size, is a 2.5, you have to loosen the Alterntor, and the tighting bolt underneath, put the belt in the groove pulleys frist and then slide the belt onto the smooth pulley
Mar 22, 2009 | 1990 Dodge Spirit
My 1997 mazda truck makes loud squeal sound when i start it and driving down the road
quite possibly the drive belt for alterntor etc loose or worn,try squirting wd40 onto belt when started and noise should dissapper if doses replace.
Mar 05, 2009 | 1989 Pontiac Firebird
Silhouette will not start, but battery put out 12+ volts
You better have the alterntor checked, you said the battery was putting out 12v. was that with the car running or off? If it was running, it should have pushing between 14 and 15 volts, if it wasn't with it running, replace alternator.
Jan 30, 2009 | 2000 Oldsmobile Silhouette
ACDelco 2001 to 2005 AC DELCO 6K815 Ford Taurus Serpentine Belt for V6 3.0L Logo
450 people viewed this question
Top ACDelco Video Game Consoles & Games Experts
James Wishart
Are you an ACDelco Video Game Console and Game Expert? Answer questions, earn points and help others
