Question about Panasonic KX-TGA660B Cordless Handset
Hand set 1 gives "insert battery" message when puting it ti be charged. Batteries are installed and ok. I also replaced batteries from another working handset but got same problem.
2 Suggested Answers
  • 17 Answers
SOURCE: ModelKX-TGA931T has 3 handsets, one of them will
Depending on how old the handset is. Go to Panasonic website and you should be able to find out.
Posted on Jun 23, 2010
HELP! ACT Emergency!
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 08, 2013 | Texas Instruments TI-85 Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
My TI 83 Plus won't turn on, I adjusted the brightness, held DEL while reinserting batteries, replaced batteries but nothing changed
hi bckyshldn,
Did you remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. In the procedure that I give, you hold [DEL] and, re-insert 1 battery. I'm going to go ahead and, restate my instructions for a ti 83 Plus that won't turn on.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me anybody could make the same mistake. and of course the calculator will never come on if the batteries aren't in correctly.
The process below should reset your calculator.
Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator did not display the message try pressing and releasing the [2nd] key followed by pressing and releasing the up arrow for one second. goto step 2.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system. If the calculator did not turn on connect the calculator to the computer and open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? goto step 3.
  3. Steps to re-installing the operating system:
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Now just in case this calculator wasn't posted correctly. Here's my instructions for a Ti 83 that won't turn on. This is not the same procedure that the Ti 83 Plus has.
  2. Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  3. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. And of course if the calculator does not turn on, I re-do the procedure and, increase the amount of time by 5 minutes to ten minutes that all the batteries are removed.
Jan 04, 2011 | Texas Instruments TI-83 Plus Calculator
Texas instruments TI-83 Plus won't turn on. I have replaced the AAA batteries.
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at ti-cares@ti.com or www.ti.com/calc.
Nov 09, 2009 | Texas Instruments TI-83 Plus Calculator
The batteries were all just replace including the lithium and it won't work I don't have cables with it does it need a download.
Usually, you should not change all batteries at one go.
It is likely that the calculator is ON, but the screen is too light to enable user to see anything. If that is the reason, you can darken the screen.
Press the [2nd] key and release it. Press and hold the UpArrow till screen darkens enough.
You can reistall the system (if needed) by connecting it to a working TI83Plus calculator. You need the calc-to-calc cable.
If that does not work, here is what the Texas Instruments Knowledge Base says about the calculator not turning on.
Without further delay, here it is from the horse's mouth (TI Knowledge base)
I hope it helps.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
Oct 25, 2009 | Texas Instruments TI-83 Plus Calculator
Wont turn on when new batteries were installed
Here it is from the horse's mouth (TI Knowledge base)
I hope it helps.
Oct 20, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
I changed the batteries and now it will not come on
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
Reinstalling the OS for the TI83/TI84 Plus family
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-84 Plus Calculator
Replaced the batteries and downloaded the software
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Panasonic KX-TGA660B Cordless Handset Logo
184 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
