Question about Cell Phones
Looking to disassemple, sufficient to allow passage of treadmill through a 30-in. door.
Do you have a schematic that will help with the disassembly?
    Master:
  • 416 Answers
There are 32,000 different tread mills manufactured to date, which one do you have??
Posted on Mar 28, 2015
Easiest way to disassemble this treadmill to fit trough a door?
unbolt the upright section from the tread section or you can simply place the unit on it's side and at an angle put the top part through the door first then do the reverse action to get the bottom bit through
once in the room simply upright it again
Oct 14, 2015 | Exercise & Fitness
Can a 9500hr next generation treadmill be disassembled to go through a 34 inch wide door opening?
Probably. Owner's manual should have instructions. No instructions? go back to store purchased from or Manufacturer.
Mar 04, 2015 | Life Fitness 9500hr Next Generation next...
Whirlpool duet wfw9450wr00
Michael, I too am looking for the same as you for my Whirlpool 8.5kg WFE1485BD. Similar machine as yours but newer. I need the schematic diagram to see how the door interlock switch works. Your problem sounds like that as well, have you tried manually working the switch with door open and checking with an ohmmeter? Does your machine give a door open warning light? I have pulled my door switch out and disassembled it but can't work out which contacts get switched. Please email me if you find a service schematic and I will do the same: steelwheels7@gmail.com
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Technogym Run Excite 700 Schematics
Dear John
Please find here in attachment the schematics for the lower kit/board for the Technogym Run Excite Treadmills.
We would be very happy to help you. So, can you please tell us where do you come from? We will put you in contact with our local customer care.
Thanks
Technogym Staff
Apr 13, 2013 | True Technogym Excite Run 700 Treadmill
Replace door gasket on GE wbvh5200j2ww
First of all, obtain a replacement gasket, then disassemble the door sufficiently to allow installation of the new gasket
Mar 23, 2013 | GE Washing Machines
My sole f63 wont fit through the door, how can i take it apart?
see the video attached and proceed according. God bless you
Other alternative is your read the instr. manual and follow the section how to assembly or disassembly your treadmills.
Dec 06, 2012 | Sole Fitness F63 Treadmill
Does Epic 425 MX parts can be removed? I cannot move the Treadmill in to my house due to too bulky for any door. Help!
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for free
from www. fitness.manualsonline.com
God bless you
Nov 18, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Have had Panasonic microwave NN-S753 several years. Worked fine, recently tray started rotating when door is opened to insert food. Despite this problem, unit continues to cook fine after time is set and...
Thanks for that ID number. That's a big help.
Now, looking at the schematic, it's clear that you would have a shorted primary latch switch (top door switch) or that switch's mount is damaged.
For safety, disassembly and diagnosis of door switch trouble, see my generic files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Mar 13, 2009 | Panasonic NN-S753 Microwave Oven
Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Jan 23, 2009 | GE JES1142SJ Microwave Oven
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
