Question about Dorman 1998-2000 Plymouth Voyager Column Clock Spring, 98-00 525-100
What would cause the cooling fans to stop working
At first the fan kept running whenyou turned off switch but it the fans wontrun at all
    Top Expert:
  • Dorman Master
  • 10,875 Answers
Relay is bad
Posted on Mar 28, 2015
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
My lg gm-313sc keep on work and stop in lest than 3 minits
The refrigeration is short cycling. The cause may be due to airflow problem. There is an outside fan thalt blows across a radiator and another in the inside the fridge enclosed behind panels.
These two fans must run and blow across the refrigeration radiators. The outside one can clog with lint and dirt, the inside one can clog with ice buid up, or the fans simply quit working. Check that the fans run and that the radiator coils are clean and clear to airflow. For the outside one, paneling will need to be removed, as well for the inside one if the outside one does not do the trick.
The refrigerator compressor short cycles because it overheats. The cool refrigeration gas entering the compressor cools it and when the gas is not kept cool, the compressor may short cycle.
There may be a different problem but checking for airflow is a start.
Jan 06, 2015 | LG Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
If running mutiple errands and the car has been startet and stopped after a few times when trying to start the engine the wont stay running.
Most modern vehicles using an electric cooling fan have a thermostatic switch that will allow them to run even after the engine is turned off. Start and stop driving can cause heat buildup in the block which can cause problems such as the one you have and if the fan isn't bringing the excessive heat down during a stop, the hot engine can refuse to idle or accept fuel as it should.
You should listen to see if the fan is turning on after the ignition is off; this is sometimes delayed for a minute or so until the thermostatic switch adjusts to the rising block temperature and starts the fan. If the main fan is belt-driven, it may be the AC fan that is used for this purpose.
Sep 24, 2010 | 2004 Mazda Tribute
1999 Hyndai Accent 1500 cc high cooling water temp.
over heating while stopped usually indicates that the radiator fan is not coming on ...when the engine is running hot you should be able to hear the fan running .. if it doesnt then suspect the thermal switch mounted on the radiator .. make sure the fan turns freely .. the fan is not needed when the car is moving so it wont heat up as long as you are driving .. but will do so when stopped if thats the trouble .. sometimes the thermal switch operates a relay that in turn operates the fan ..that could also cause the trouble ..
Jun 10, 2010 | 1999 Hyundai Accent
Cooling Fan won't come on, coolant flows into overflow tank
there is a switch in the engine intake or cylinder head that controls the cooling fans. The switch is the one with only 1 green wire hooked to it. Turn the key to run, with the engine stopped pull this wire off and touch it to a ground( cylinder head, engine block) and the fan should start, if not look at the fuse, if it does you need to replace the switch.
Mar 13, 2010 | Chevrolet Celebrity Cars & Trucks
Radiator Fan Stays On
A simple test would involve disconnecting the fan switch while the fan is on. If the fan then stops the switch has failed. If the fan continues to run remove the relay , if the fan then stops the relay has failed.
Various inputs/outputs at the relay should be confirmed to be 100% certain something strange isn't going on.
Above all be careful of the fan itself , if it's running obviously but if it's not it could start during repair
Mar 01, 2010 | 2001 Buick LeSabre
My oven is constantly blowing out air at the front? Why
Your oven has a fan to draw in cool air at the bottom of the front panel, pass it around the case, and then blow it out at a position towards the top of the oven. This is a completely different fan that is at the back of the oven itself.
The cooling fan is necessary as the materials in modern ovens are kept light and thin as possible to save weight and manufacturing costs, however the flipside of this is that if not cooled by the cooling fan, they would be damaged by the heat inside the oven itself.
The cooling fan will continue to run for some time after the oven is switched off, because it will wait until the oven has fully cooled down before stopping the cooling fan.
Oct 03, 2009 | AEG B1180-4 Electric Single Oven
98 Civic with non-functioning cooling fan
bad thermostat or worse a plugged heater core or bad summer/winter diverter valve. look for bad thermostat.
Dec 08, 2008 | 1998 Honda Civic
Dorman 1998-2000 Plymouth Voyager Column Clock Spring, 98-00 525-100 Logo
43 people viewed this question
Top Dorman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dorman Audio Player and Recorder Expert? Answer questions, earn points and help others
