Question about Samsung Televison & Video
What's the fix for a flickering screen on a Samsung ln40a550p3fxza. No matter what is on the screen from a movie to the tv menu it will randomly flicker for a few minutes then stop for a while.
    Master:
  • Samsung Master
  • 996 Answers
CFL light should be replace
Posted on Mar 28, 2015
  • Anonymous Mar 28, 2015
    I'm not sure it would be the light due to the tv has been flickering for a few years now.
  • 579 Answers
SOURCE: Samsung TV flickering
This is an unusual failure of a non obvious part in the power supply putting noise into the circuitry of the TV.
you either need a competant tech to work on it or if you are good at connecting up cabling just swap out all the guts.
call Module Exchange at 972-298-1212
Posted on Jan 01, 2008
SOURCE: RCA TV flickering problem
Help! I have an RCA 40 inch HDTV (Model# D40W20). I've had it since 2005. Recently, the picture will flicker when I turn it on, but will stop flickering after a few minutes. My brother has the 52 inch model and his tv did the same thing before it broke down completely. Does anyone know what the problem could be?
Posted on Jul 24, 2008
stonephoenix
  • 563 Answers
SOURCE: when i turn on my samsung lnt5271 the screen seems
This sounds like a repair issue. I do not believe there is any in-home troubleshooting that you can try that will fix that particular issue. I would call Samsung tech support to see what their opinion of the problem is. Their number is 800-726-7864.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
  • 14 Answers
SOURCE: I have a Maxent 42 inch plasma.When you turn it
What is the Product Name or Model number of your Maxent 42" Plasma TV? If it is a MX-42X3, Model # P420542HM8, I think I can help you. I have encountered this exact same problem with 2 Maxent MX-42X3 Plasma TV's. I found that C766, a 220uF, 16V surface-mount electrolytic capacitor on the main board is bad. This capacitor is located just to the left of the green multi-fin processor heat sink. This capacitor will test good using capacitor meter or an ESR meter, but if you spray it with Freeze-It with the power on, you will find out that this is the problem! To get it out, I found I had to remove the little 10uF 16V surface-mount capacitor just to the left of it. I then replaced these 2 capacitors with regular (radial), high-temperature, low-ESR capacitors. I cut the leads short, and bent the ends out just a little bit so you can solder them back onto the surface-mount pads. You can get these parts from Digi-Key Corp. I used Digi-Key part # P12383-ND ($0.32) for the 220uF capacitor, and P11212-ND ($0.30) for the 10uF capacitor. Both of these capacitors are rated for 25V and high temperature, so they won't go bad again. You can purchase surface mount capacitors there too, but I find them very difficult to solder back into those locations due to the tight placement of other capacitors in that area. If you're not an expert in soldering, I suggest you take the main board to a qualified electronic technician, and let him do it. But you better put the board in an anti-static bag before you take it anywhere! Hope this helps!
Posted on Nov 16, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
SAMSUNG lcd tv hdmi repair
The first thing you need to do is go into the settngs menu and see if you need to enable it, if there is no such menu setting, you need to change a board on the unit or use the repair kit if you are good at soldering http://www.shopjimmy.com/samsung-bn94-02077c-main-board-component-repair-kit-for-ln40a550p3fxza.htm
Apr 28, 2016 | Samsung LN40A550 LCD TV
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Samsung LN40A550P3FXZA lcd TV (purchased 2/08) started turning off and on, neither the remote or side buttons will work, how do I fix this problem?
check for power supply board malfunction, replaced first bulged electrolytic capacitor. just let me know if it works.
Aug 03, 2012 | Samsung LN40A550 LCD TV
PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Samsung LNT4669F Pixcels Flicker
As long as you only see these artifacts while watching certain broadcasts, the TV is fine.  If these lines are present no matter what you are watching, then you have a problem. What you are seeing is signal related and there isn't much you can do to fix that. Think of it like a scratched DVD; you will see strange things on the screen at times and many think it's the TV when it's only the signal from the device to the TV that is corrupt.
I have thought of one possible solution and this will depend on your TV's ability to slightly stretch the picture in vertical/horizontal directions.  If your TV will let you, you may be able to raise the top of the picture a cm or so to hide the flickering.  Check the TV's onscreen menu for anything to do with picture alignment.  This is nothing to do with aspect ratio though so ignore that.
Mar 24, 2009 | Samsung LNT4669 TV
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
196 people viewed this question
Jerry Greenberg
Jerry Greenberg
