Question about Taylormade Taylor Made Golf- RBZ Rocketballz Stage 2 Driver
Adjust loft on RBZ driver
I need to adjust the loft as high as I can beyond the standard 10.5 degrees can I increase the loft beyond 12 degrees
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Sep 19, 2017 | KitchenAid Refrigerators
What is proper ignition timing adjustment for 1989 GMC S-15
the correct timing will be 12 degrees before TDC. It can be adjusted to 10 degrees but not over 12.
Sep 11, 2014 | 1989 GMC S-15 Jimmy
Temperature problem solving
50 degrees.
If this is homework, be sure to show your work.
Dec 04, 2013 | Office Equipment & Supplies
Poor performance at high revs
In this case i suggest you to go through this following help links.Click the link below to troubleshoot the procedure :----High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html----------rpm needle bounces? http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html--------------How to adjust rpm ? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html---------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html----------consuming more fuel? http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html-----------How to maximize fuel economy on your vehicle? http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html----------
How to Perform a Basic Engine Tune-Up
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up.html-----------How to Increase gas mileage? http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html----------
Adding performance chip to increase Fuel mileage MPG? http://technoanswers.blogspot.com/2012/01/adding-performance-chip-to-increase.html
----------This will help.Thanks.
Feb 16, 2012 | Cars & Trucks
3.5l dohc 95 model idles but wont rev chokes and splutters engine recently rebuilt
Sounds like the timing is off or something wasn't synch'd up correctly during the rebuild. Check the timing and make sure the vacuum lines are connected correctly, especially the vacuum advance which advances your timing when the engine RPM's are increased. Start your timing at 5 degrees before top dead center, the 5 mark on your timing marks, this is the most common baseline setting for timing. If you have to set it advanced beyond 10 degree or retarded beyond 0 then your timing chain was not aligned correctly between the Pistons and the Valves or cam shaft.
Nov 11, 2010 | 1995 Mitsubishi Montero
I have a new Sears 315mhz garage door opener and the door fails to reverse when an object is placed under the door
It sounds like the force adjustment may be set too high. Check this:
The force adjustments control the pressure used to open and close the door. A new garage door opener from the factory is set to the lowest possible force adjustment. If you have a properly balanced door, the forces required to open and close the door should be minimal.
The force adjustments are usually located on the rear of the garage door opener and/or under one of the light lenses, If your opener has two lights. If you have lights on the side of your opener, the force adjustment will be located under the right light lens. The force adjustments are labeled with an arrow indicating open or close and numbered 1 to 9, with one being the lowest force and nine the highest. The force adjustments can only turn 260 degrees, or ¾ of a complete turn. Changes to the forces should be done in 10-degree increments. Please remember that too much force will interfere with the proper operation of the safety reversal system. Do not increase the force beyond the minimum required to close the door. Do not use the force adjustments to compensate for a sticking, binding, or unbalanced door.
Mar 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Everyday is a summer day here. i just bought yamaha R6 2009 model. the engine temperature increase quite fast. in 12 minutes time it can reached 200 degree F. what can i do for the temeperature to increase...
hi buddy you have nothing to worry about the temperature on the radiator is a fan which should kick in at 105c and 1500 rpm is fine for your bike its standard setting which means at 1000pm the bike will continuouly cut out and this rpm get back to me if any probz bud
Dec 01, 2009 | 2008 Yamaha YZF-R6
Need 1990 nissan sentra torque settings and valve clearence
heinrichkemp: The engine in your car is a GA16i
I venture you are asking about the head bolts when you refer to torque settings. The head bolts used on this motor are torque to yield (streach bolts) If you are reusing them, you need to check them to insure they are not stretched beyond limits.
The way you measure the bolt is with a micrometer.
Measuring close to the end where the bolt starts to thread in, about 10-12 threads up, take a reading. Now, go to the other end of the bolt where the threads end and measure about 10 threads in.
There should not be more than a .009 inch difference (.228mm). If there is, discard the bold and get a new one.
You must use a sequence to tighten the bolts, below is the sequence.
11
13 9 3 1 6 8
14 7 5 2 4 10
12 15
torque 11,12,13,14 & 15 to 8.3 Nm (6.1 ft lbs)
Torque the main head bolts by the numbered sequence to
29Nm (22 ft lbs) first pull
64Nm (47 ft lbs) second pull
Loosten all the bolts completely
Tighten the to 29Nm (22 ft lbs) first pull
Tighten bolt # 1 clockwise 85 degrees
Tighten bolts #2- 10 65 degrees
Nissan noted that if you do not have a torque angel meter, you can use a regular torque wrench and torque all the bolts to 69Nm (51 ft lbs)
The valves on this engine have hydraulic lifters, consequently require no adjustment.
Apr 11, 2009 | 1990 Nissan Sentra
Top panel bubbling and peeling off
I would suggest that the humidity and high temperatures in your loft has weakened the glue that holds the laminate onto the base. Temperatures in lofts/attics can be very high during the summer months.
Mar 11, 2009 | Technics SL-1210 Turntable
If you zoom to less than 12x
Sorry you're having such a problem with the fz1 w/b-macro. Here is a shot of the stock fz1 w/b-macro at full 12x zoom - resized only. Try practicing on still objects such as coins or jewlery. If you are beyond 10-12 inches you are probably too far away.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Taylormade Taylor Made Golf- RBZ Rocketballz Stage 2 Driver Logo
754 people viewed this question
Top Taylormade Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Taylormade Golf Expert? Answer questions, earn points and help others
