Question about Homelite Garden
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
  • Eugene Rounds Mar 28, 2015
    Hi Robert Topham, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Incomplete UT- number missing a digit. Also is it a clutch or non-clutch model?
  • Robert Topham
    Robert Topham Mar 29, 2015
    Unit is a Clutch model, model No is UTS2078. Since posting I think I have identified problem in that engine will part fire when misture needle screwed right out indicating possible blockage under jet hole in bottom fuel bowl, noted that under pressed jet there appears to be a rubber grommet linking to neddle seat. Unable to remove jet hole as presed in. Unfortunatley it appears that original varble is no onger available, single mixture control needle, high speed needle hole bloacked off with steel pin having no function. bottom line is is there any alternative Zama carbies that may have the same specs as the original?
  • Homelite Master
  • 1,169 Answers
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Posted on Apr 01, 2015
#1 Taper
  • 1041 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
SOURCE: Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
Posted on Jan 09, 2010
SOURCE: Homelite curved shaft timmer line problem
It sounds like its a bump feed which they usually are, try turning on the machine and bump the head off the ground. If this fails to work try rewinding the line on tightly and neatly with no parts of the line crossing over as this could knot it. Quick tip most heads have a arrow pointing the direction to wind the line.
Let me know if that works.
  • 6 Answers
SOURCE: Can't figure out how to replace the trimmer line
Throw the trimmer spool in the garbage and get a Gator head. It will be the best $20.00 you ever spent.
Posted on Mar 31, 2010
hunter19_46m
  • 7482 Answers
SOURCE: What is the high /
Hi dcheddy...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have tried to adjust them already then this should get it running...then do your final adjustment when the engine is warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Free Answer...Please take time to rate me
Posted on Jul 09, 2011
Homelite Pro weed trimmer, model TLT254EBC. Where can I find a replacement carb?
go to any mower shop that repairs homelite and get one
go on line to homelite select the page for replacement parts and order on line .
previous pages give a price between $12 -30$ us.
try e-bay for carby
May 20, 2015 | Homelite Garden
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Primer does not work
Homelite Tune Up
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
Bulb will not prime
Homelite Tune Up
Homelite trimmer F2020
One of the most common failures would be the smallest air leakage in the pickup tube. the siphon effect is cancelled by an air leak too small to see. If the trimmer will start momentarily or "pop over" when fuel is administered directly through the venture or spark plug hole then the issue is definitely fuel delivery. bad diaphragm, swollen fuel lines or a blockage in the main jet or venture tube.
Oct 24, 2017 | Tools & Hardware - Others
I purchased a model f2020 weed eater from bunnings naenae the line cartridge broke up and i went to get a replacement from bunnings they don't stock homelite parts but ordered one for me i have been...
You can order the part from www.homelite.com You will need your model number to help you select the right part. You will need to click on the order parts text in the upper right hand part of the screen. This will take you to another page which will ask you to go to the homelite parts catalog. After you click on the parts catalog link, it will ask you to agree to the terms of use for the website. READ THIS CAREFULLY.
After you have agreed to the terms of use it will take you to another page. From here you can input the model number of your unit. Input the f2020 into the search box and click on search. It will ask you which version of the model you have. On the right side of the screen it will have a parts breakdown. You should select (Shaft-Spool and String- Grass Deflector). This will pop up a diagram with a parts breakdown which will include part numbers to help make ordering the correct part easier. I believe the part that you wish to order is part number 17 of the diagram. When you click on the part number in the diagram it will select it below the diagram and will flash for a second. At this point it has an option to add this part to your shopping cart.
I hope this helps get you back in business.
Apr 02, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
154 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
