Question about Winter Sports
Hi just wondering if there is anyway I can get my sled to run without the battery! Thanks
2 Suggested Answers
commanderzod
  • 112 Answers
SOURCE: Hi, can I operate the A 70 on mains power without a battery
Your battery will not charge until it reaches a lower limit of charge.
Whilst in the Laptop and using mains power your battery acts like a UPS and is available soon as you lose power.
The battery life will not be degraded or improved, removing it whilst plugged into mains.
When using Laptop om=n mains the battery is always there in case you lose power or somehow the lead gets pulled out inadvertantly, so you will not lose work.
I use a laptop all the time for work just got a new Latitude D630. The battery in my old lappy is still good for 2hrs+ and never been removed.
80% of its life was on mains.
Hope this helps.
Posted on Nov 14, 2008
Headlights work fine. Why are all gauges/ electronic dash out?
Electrical issue - no headlights, tach, etc - HCS Snowmobile Forums
www.hardcoresledder.com > ... > REV Chassis
Feb 2, 2009 - 12 posts - ‎2 authors
There is no voltage at the harness with the relay at all. ... Previous Sled(s): 09 f1k SP,07 f8 SP,fusion 600@900 ... We havea 2006 600sdi and everything works but the headlights. ... relay is good, But this just happend to me sled starts and runs fine ... As soon as I rev it up the dash, tach, headlamp go out.Missing: 600headlights ‎electronic
06 fusion 600 bad volt regulater [Archive] - JohnDee.com ...
www.johndee.com > ... > Discussion Board > Tech Talk
John Dee
79 posts - ‎8 authors
I believe I have a bad voltage regulator going out on my sled. lights are diming and ...I'm under the impression that polaris has replace the old regulator with a new ... They are way down under the oil tank, brake, and all that stuff, up tight ... While riding, my sled had dim lights, no hand warmers, gauges would go in and out.Missing: 600headlights ‎electronic
Polaris Fusion 600 HO LED tail lights - YouTube
? 0:31
https://www.youtube.com/watch?v=oG2BWF4xVKg
Sep 28, 2011 - Uploaded by Trent Robinson
Most Fusion 600 HO owners at some point have issues with their ... This makes sense but the electrical system is AC on this sled AND people complain of the brake indicator on the dash stays onall of the time. ... Not sure on the indicator, mine works fine. ...2006 Polaris Fusion 900 that we are parting out.Missing: 600headlights ‎gauges ‎electronic
battery light blinking with full battery - TrackShare.com
www.trackshare.com/forum/showthread.php?t=32645
Jan 01, 2016 | Polaris 2006 Fusion 600 HO
Can I use a truck battery to boost my sled
Hi Roger
Any 12v battery can be used to boost another 12v battery.
MAKE SURE THE SLED BATTERY IS NOT FROZEN!
Mar 04, 2015 | Cars & Trucks
Can plug wires be crossed?
I have the Same Sled and It runs pretty good. Love the fact that it can start with the push of a Button but to answer your question, the Wires are separated so that they should automatically go to the Right Cylinder and if I remember correctly, they SPARK identical so if they do fit (Mine Won't) it should start anyways. a DEAD BATTERY will not allow the sled to start, it is SDI (Semi-Direct Injection) and it requires power to Work....
Feb 24, 2015 | Ski-Doo 2004 Legend GT Sport 600 H.O. SDI
I have a 1993 arctic cat 700 efi that the battery keeps going dead in how do I check if its charging?
When a battery dies while the engine is running it is not being charged. When the charger is working the engine will run without a battery
Dec 13, 2014 | ATVs
Power loss at high speed
no sounds like u may have a fuel and or electrical problem or both
Feb 26, 2009 | 2006 Yamaha YZF-R1 SP
Dont want to save suds.( Kenmore model 5450290 Suds saver washer)
disconnect the wireing to the suds saver valve and tape the ends off.
valve will no longer open for the suds cycle
Jan 30, 2009 | Kenmore Washing Machines
Harley davidson won't start
Test for power to the solenoid when you push the starter button. This should help to eliminate the switch, relay,wiring etc. You can also run a jumper wire from the large (power) cable on the top of the starter to the green wire on the white connector on the end of the starter.
Nov 22, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Hope this helps.
Nov 14, 2008 | Toshiba Satellite A70-S249 Notebook
Winter Sports Logo
468 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
