Question about Radio Communications
My hv 800 headset is blinking red and blue. What do I do?its fully charged and I just bought it a week ago.
samkong
  • 106 Answers
SOURCE: My headset does not hold its charge
Usually Lithium-Ion batteries have a Memory effect, ie. the battery should be 100% consumed then only recharged. If the battery is only 40% used and recharged then the battery will give you only 40% of it's total charge. The battery starts showing you empty after it is 40% consumed even it was 100% charged. Now there is solution for this-Drain battery upto full, store it in a cool place like Frigde then charge it full then again use it upto last. Repeat this procedure for 2-3 times.Your battery should come to normal state. Also check the charging current of the charger.The charger might also be faulty.
Posted on Apr 26, 2007
SOURCE: Samsung WEP200 Headset will not charge up
I am having the same problem! Have you had any help?
Posted on May 02, 2008
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
Tap the answer/end button on your headset to answer a call
End a call
Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
Press the answer/end button to turn on your headset
Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Posted on Jun 16, 2008
  • 6 Answers
SOURCE: will not turn on or charge
get warranty on that one.
Posted on Jun 23, 2008
SOURCE: motorola H550 bluetooth headset
im having the same problem
Posted on Aug 30, 2008
So it was connected for a while. but now it's not. and it's a blue color. it won't turn off, it stays blue, and my phone cannot find it anymore in the bluetooth section. How can i fix this?
Do not know this is what I found on the internet have no experience with the hv-800
To pair the headset, please keep pressing the turn on off button until the red and blue light flashing. ( I think this translates to holding the power button in for a certain time period - think it got lost in translation from chinese to english - somewhere )
on the phone search for bluetooth devices while headset in pairing mode
if asked to enter the password, please enter 0000, confirm and then the Bluetooth enabled device successfully connecting with this product. The blue light will flash two times every 5 seconds after a connnection.
Sep 04, 2015 | Unknown HV-800 Wireless Bluetooth Music...
I just bought th hv 800 bluetooth headset, when i
might indicate it is fully charged already .
Sep 23, 2014 | Radio Communications
I am trying to charge my Plantronics M100 blue tooth. I will not charge and the light is flashing red continuously.
If headset does not charge and light blinks red continually, it is defective and will need to be replaced. It comes with a one year warranty. Call Plantronics at 1-800-544-4660 x 5538 for assistance.
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics M100 Bluetooth Headset
I'm charging the headset and the led is blinking red, but when i disconnect the usb, i still can't turn it on
When the headset's battery is fully charged (about 3 hours), the indicator light is steadily lit in blue
Aug 18, 2010 | Motorola Mobility H270 Bluetooth Headset
Will not turn on or charge
Jun 23, 2008 | Jabra BT125 Headset
Radio Communications Logo
381 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
