Question about Cub Cadet Garden
What is the valve adjustment on a zero turn z force Cub Cadet with a Briggs and Stratton engine?
  • Eugene Rounds Mar 28, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Need the model of the Briggs to give the correct gap setting and the procedure of adjustment.
How do I ADUST the valves on my cub cadet rzt zero turn lawn mower???
you will need to take it to shop it is complicated to do
Apr 17, 2014 | Garden
I have a cub cadet rzt zero turn lawn mower that I'm trying to get started need to know how to adjust the valves on the mower
Can't say with knowing what engine you have such as Kawasaki, Kohler or, Briggs and Stratton.
Cub cadet lt 1042
Some of those cadets (like those with the Command 20) have a compression release mechanism on the cam which is intended to make that engine crank easier but disengages once the engine fires up. It's a plastic part and is prone to break, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad cam is a bit of work but not terrible.
Oct 04, 2013 | Cub Cadet Garden
Briggs and Stratton 24 HP ELS engine common cause of vacuum leaks causing engine to run poor
im not sure on an answer but i do know 200 lbs is way too much compression. go to a good lawn mower shop and talk to service. they should be able to give you a direction on this problem
Jul 25, 2013 | Cub Cadet Garden
Cub cudet 31p7770299e1 briggs stratton engine
only thing left is valve seat is loose and poping loose at a certain rpm causing backfire threw carb has to be intake valve
Apr 23, 2013 | Cub Cadet Garden
check and see if intake valve seat is loose as motor gets hotter condition worsens
I have a z force s cub cadet. The battery is good. Tested and passed. the engine/started must work hard to turn over, but still won't catch. I will jump the tractor and it will start and run.
You may want to try to find a battery with a stronger amperage rating. Even if the battery passes if it is borderline for starting it new it may not be strong enough even if it's still okay for it's battery type.
Other causes:
A worn starter can cause this issue. If a few of the coils shorted the starter will work but require much more current to do the job
A bad relay/solenoid to the starter that doesn't allow enough current to go through can cause this.
Valves out of adjustment... especially on some Briggs and Stratton engines, it's a known issue that if the valves need adjustment the motor can require a lot of energy to turn over and can cause constant hard starts.
Mar 28, 2013 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Apr 18, 2009 | Briggs & Stratton Garden
Garden Logo
137 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
