Question about Karcher K2.350 1600psi Electric Pressure Washer - -
My Karcher k2.350 inlet elbow joint has split right down the middle leaking water everywhere.I can't find the part number from Karcher and so far they have not replied to my emails.Could you olease help me in finding the parts number or where to buy the part from.Thank's.
4 Suggested Answers
  • 11 Answers
SOURCE: karcher k2 power washer inlet-outlet manifold cracked along weld
well depends did u use it in cold tempatures if so no it was u. if not then most likely or could have been just a crazzy thought here that there was a electrical discharge when it was pluged in and cracked the block on it but honestly thats 1/10000000000000 chance of happening. or it overheated and cracked it but relistically if its new then just take it back and play dumb or if its still under warrenty play dumb and get it fixed. aslo u can search for a new part on craigslist or ebay. last but not least if its not uner warrenty or new to take back or u cant find a part either thru the ones i listed or by calling the man. ur last resort is to just throw it away.
Posted on Apr 03, 2009
delgriffith
  • 97 Answers
SOURCE: karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Posted on Jun 19, 2009
cool78259
  • 228 Answers
SOURCE: My Karcher 330 M has blown two water inlet (
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Posted on Jan 04, 2011
Hi i have a karcher k4.91 and it is lossing pressure and leaking from inside the casing..what would be the likely cause.. many thanks
This could be a problem in the pump, the seals may have been damaged if it is an older machine through age. You could check a local karcher supplier/dealer and they should be able to replace that for you. Another problem maybe that an inlet elbow could be loose and does not seal correctly so it may need replacing.
These solutions depend on what area inside the machine the water is leaking from.
Jan 11, 2011 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Water freezing in ice maker inlet tube
yes exactly,
follow your tube down to the water vavle you probaly have a small leak in the solonoid and it is dripping up
hard to beleive but it is
you can also turn down your freezer just a bit
but you will find the replacement water valve at the
www.appliancepartspros.com
just type in your model number
Nov 04, 2009 | Refrigerators
Water spraying out of the front vent of unit.
Dear zenith 10deg,
The outlet elbow attached to the head inside must have cracked. Leakage from selas do not that much spraying. Spraying are almost always caused by the cracking of the outlet elbow or the cracking of the head itself. The inlet elbow also makes a lot of spraying wheb broken, especialy if inlet water pressure is high. To see exactly from where the spraying is coming out, one must for sure remove the cover. Removing the cover must be done, because just the same one has to fix the problem.
Regards,
fulltech.
Apr 08, 2009 | Karcher Garden
Water coming out of washer
Depending on the model of the machine, it is most likley a cracked control head or split outlet elbow. Remove the covers and run the machine to locate the source of the leak. Ifit is the control head it will spray water from the top just behind the chemical inlet elbow.
Feb 06, 2009 | Karcher K2.26 Electric Power Washer
Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Jan 07, 2009 | Karcher Quick Connect Nozzle Set
My Karcher HD 1050 DE has lost pressure, ive had new valves put on it but still has no go in it
could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
Oct 12, 2008 | Karcher 2500 PSI Pressure Washer
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
your tub seal needs to be replaced. you might have damaged it when you moved it
Jan 25, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Karcher K2.350 1600psi Electric Pressure Washer - - Logo
71 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
