No power to no light anywhere. on the desktop towards
    Master:
  • 996 Answers
Power supply or its wires defective
Posted on Mar 28, 2015
We put our Acer desktop to sleep last night and now the keyboard won't activate-no lights on function keys or anywhere else.
Have you tried disconnecting the power supply and battery for about a minute.Then reconect the battery and power and restart.Has worked for me
Oct 23, 2012 | Acer Power S285 PC Desktop
The power green light on my hp pavilion t450 uk pc keeps on flashing and my computer is not coming on
i have the same problem and my power button is broken. i just stick a knife in the side of the button and wiggle it around. maybe your power button is ********.
Aug 28, 2011 | HP Media Center m7250n (ED842AA) PC...
I have a dell dimension E521 and it no longer powers up. When turned on rather than booting it up the light just flashes orange. The advanced troubleshooting says # If the power light is blinking amber,...
You are correct. According to the Power LED it diagnoses this as:
The power supply is receiving power from the source but is unable to properly distribute it to the components. Reseat all power connections to the system board.
It's either the power supply or the motherboard. Power supplies run anywhere from 50 to 100 dollars. Motherboards for the Dell can run anywhere from 200 to 300 dollars plus labor. Also check your USB ports to see if any are damaged. They can short out your power supply if broken.
Jan 09, 2011 | Dell Dimension E521 PC Desktop
My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the Power On LED light.
Pin 1 is for the Positive ( + ) wire.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Aug 23, 2010 | E-Machines T3302 PC Desktop
Power Supply either dead or pretending to be.
Check the fan if there is an air coming out,
Jan 13, 2010 | Computers & Internet
My phillips freevents x55p had gone into a sleep mode. when i tried to start it the screen flashed and then everything died. It was on ac power with the battery fully charged. it does not repond to the on...
removed battery pack. it then ran ok on mains power adaptor. battery but would not run either on battery alone or on battery + mains. battery pack is faulty.
Jul 31, 2009 | E-Machines eMachines Desktop PC
Packard Bell Easynote - not powering up
If this is a notebook , hold the power button down for about 6 seconds to make sure this is not just in hibernate. Make sure it is plugged directly into the wall power outlet , not a power strip.
Some laptops have a power increase when plugged into the wall and less when running off batteries.
Nov 05, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
