How do I remove drum
What holds it in place after agitator is removed
  • Washing Mach... Master
  • 5,323 Answers
U need a tool called a spanner wrench that removes the metal nut at bottom of agitator.
Posted on Mar 29, 2015
SOURCE: Now do you remove agitator from washer drum?
There are 4 holes at the base of the agitator. Use a screwdriver to push in at each hole in order to pop the plastic grove that holds it in place. The agitator cap will then pull off to reveal 6 3/8" bolts. Remove these with a socket set and the entire agitator can be lifted to free the garment. To reassemble, position the agitator holes over the holes in the base, reinsert and tighten the bolts, snap the cap back on, and your are ready to go.
Jim
Posted on Jul 12, 2008
  • 326 Answers
SOURCE: I am unable to remove the agitator from my Kelvinator K605 washin
 Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
he agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
read more about the agitator removal in the next comment.
Posted on Jan 30, 2009
  • 77 Answers
SOURCE: cant remove agitator. Fabric softener cap is off but i do not see a screw or bolt to remove the assembly. agitator is only weakly working
There should be a 7/16 bolt in the bottom of the cup once you have taken the cup out. Its kinda deep you would need a longer extension. Also this agitator bolt usually has a gasket material attached to it and it may be covered by another cap.
Posted on Apr 17, 2009
SolutionGuy
  • 331 Answers
SOURCE: Removal of agitator
I gotta congratulate you for taking on the toughest job on your washer. The transmission replacement is daunting if you've never done one before.
OK... about your question.
Here's a place with detailed instructions (and pictures) on how to do the 2X4 trick. If after doing that you still can't get it, then try tapping (actually a little more than just "tapping") the agitator with a rubber mallet. This will (hopefully) loosen any rust on the splined shaft allowing the 2X4 to do its' job.
As a last resort, you can get yourself an "Agi-Tamer". It's a tool that we in the appliance repair biz use for just this problem. It's a snazzy little gizmo that fits between the bottom of the agitator and the tub. It has a water hose connected to it... you then take that hose and put it on the cold water valve behind the washer. Then you slowly open the valve filling the Agi-Tamer with water. As it fills, it expands and forces the agitator to lift with it. You have to be careful, though. I've seen agitators fly off the shaft like a cork from a champagne bottle! So if you go this route, put your 2X4 over the agitator as the Agi-Tamer fills to keep it from flying, OK?
(*NOTE* ---> the link to the Agi-Tamer above shows one designed to use air pressure, not water (like the one I use). I've never used one with air, but it appears that it'll hook up to a bicycle tire pump or one of those inflatable swimming pool toy electric pumps. Just a word of caution here... knowing what I do about Hydraulics and Pneumatics, the pneumatic model WILL MOST DEFINITELY BLOW THE AGITATOR OFF THE SHAFT!!! So, take care if you use that model, OK?
Now where to get one. This is a specialty tool sold to appliance repair guys (and girls... although I've never HEARD of an appliance repair girl). You may try calling a local appliance parts retailer and see if they have one in stock or look around on the web. They run about $50, so it's kinda pricey to buy it only to be using it once... why not call an appliance repair company and explain what you're trying to do. Ask them if any of their technicians carry an Agi-Tamer on board their sevice vans. Then maybe work out a deal to rent it or borrow it. Or you may simply schedule one of their technicians to come over and remove the agitator FOR you. <--- That's probably the way to go, btw. Using an Agi-Tamer is kinda dangerous and a reputable company might not want to take on the liability of you using one of theirs just in case you poke your eye out or something.
So there ya go, KR! I hope this solution was satisfactory for you and that it helps you get that pesky agitator off. If it did, please remember to rate me as "it solved my problem", deal?
SG
Posted on May 17, 2009
SOURCE: replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Posted on Jun 13, 2009
The machine will not agitate, but will spin dry and drain. Kenmore model 110.
When the agaitator doesn't work yet it spins/drains it is usually the agitator dogs that are worn out.
This tip i wrote about the dogs expalins in detail what to check and how to replace the dogs.
http://www.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Aug 31, 2011 | Kenmore Washing Machines
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Cleaning the drum of the Whirlpool 3 LSR 6233 EQO (get it out)
Remove two screws that hold the control panel,pull forward and lift ,tilt back. Unplug door switch and remove the gold clips that hold the back to the top of washer cabinet. Lean cabinet towards front and remove. Unsnap tub ring at top from outer tub. Remove fabric softener dispenser cup at top of agitator. Remove snapped in plastic cover and seal underneath. Remove bolt under the cover. Remove agitator. Remove spanner nut that holds drum in and remove drum.
May 13, 2009 | Whirlpool LSR6332K Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Jul 15, 2008 | Admiral AW22 Top Load Washer
washing machine is not working properly kindly advise who can repair in south delhi in Devli Village, Near Khanpur, New Delhi-110062
Jul 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Water leaks from main seal
Up front, this project requires specialty tools made by the manufature to remove the seals. You can check with your local parts store or the manufactures web site to purchase them. To remove the outer drum, you have to take the 2 panels off the front and remove the screws underneath that are holding the top of the unit. Lift the top up and lean it back. Next you have to remove the tub ring (the white plastic peice on top of the tub and basket) Next you remove the agitator. Underneath the agitator, there are bolts that hold your inner basket in. Remove these and pull out the basket. Next you have to use specialty Amanna/ Maytag tools to remove the seals that are sitting on top of the center shaft (transmission). Next remove all hoses going to the tub ( some will still have water in them) Lastly there are bolts all of the way around the base of the washer that hold the tub in place.
May 30, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
