Question about Acer Computers & Internet
I have problem with laptop acer aspire 7551, not TV. Anatoly.
I push button on fan work 3 second and stop. NO screen. Power light bulb. Laptop Aser Aspire 7551. AThanks. Anatoly
    Master:
  • Acer Master
  • 996 Answers
Install window corrupted
Posted on Mar 28, 2015
    Top Expert:
  • Acer Master
  • 25,361 Answers
Probable GPU issue caused by overheating. Reball the GPU.
When I push power button it will light up for about 3 seconds and go off. Fan does not come on.
Take out the battery, unplug laptop first. Hold power button down for 60 seconds and release. Then, with battery still removed, plug in laptop and try to start it up. If it comes on put the battery back in.
Mar 19, 2016 | Acer Aspire 7560-Sb416 -25520
Cut off while in use and will not come back on
Not a fault you'll fix yourself. Take it to an Acer Service Centre. From my experience with Acer laptops, it's often the motherboard that fails - usually just months after the warranty expires! If that's the case it'll probably be as cheap to buy a new one.
Mar 08, 2014 | Acer Aspire V5-552P-X440 15.6-Inch...
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
Acer aspire 7551-2961 won't boot up.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Acer Aspire 7551 AC Adapter 90Watt 19V 4.74A
Jan 13, 2013 | Acer Aspire Computers & Internet
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
ACER ASPIRE 3690-2940
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Acer aspire 5630 BL50
You can try basic troubleshooting. Unplug the laptop, takeout the battery. With the laptop still unplugged, put the battery back in and power-on the laptop. If that doesn't work and you hear no beeping sounds, the motherboard maybe bad and needs replacing.
Apr 05, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
