Question about Hitachi Televison & Video
My 54inch Hitachi Projection tv just stopped working. The power shut off and does not want to turn back on. We tried to take it apart and see if we could turn it on but no luck. What wrong and Is it fixable?
    Master:
  • Hitachi Master
  • 996 Answers
Check mainwire or power off switch ,then mains wire & then fuse,,,otherwise power supply circuit,,,should be repaired by an expert professional only
Posted on Mar 28, 2015
Ecollier2012
  • 3459 Answers
SOURCE: hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Posted on Jan 29, 2009
SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
Posted on Feb 06, 2009
  • 65 Answers
SOURCE: Hitachi projection TV does not power up
You probably have a blown 2kV capacitor and 2 amp fuse. Look for signs of black burning inside.
Posted on Aug 09, 2009
SOURCE: Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Posted on Aug 16, 2009
rob1984
  • 7 Answers
SOURCE: Projection TV not working
The Convergence IC's have went out. This is normal for this TV after about 5 years or so. You will need 2 sanyo STK392-150 IC chips, and about 6 resistors to fix. The cost is about 50 US dollars if you do it yourself. If you are not good at soldering, don't try it. However if you are, and can read an ohmeter it will be no problem
Posted on Dec 28, 2009
I have a 61 inch rear projection TV. When moving we took the back off of the TV so that we could navigate it up the stairway to my new apartment. Once in the apartment we plugged it in and it wouldn't go...
Check ur power source?Yes,wait like about an hour later for the tv resetting back to it factory setting.Recheck all connections inside of the tv for loses or untighten connections?Make sure all connections are tighten and no damage to all the PCB boards tries again tv should work now.
Jan 14, 2011 | Hitachi 61SWX10B 61" Rear Projection...
I have a Hitachi Ultravision Projection TV Model 57XWX20B. My TV will not stay on. I tried unplugging it, then plug it back in. It will then click once to turn on; then after 15 seconds it will turn off. ...
The power source detects an overload on one of its exits and shuts down to protect itself. The tv must be opened and tested by a knowledgeable person who can identify and replace the failed part.
Aug 22, 2010 | Hitachi Director's Series 57XWX20B 57"...
Tv stopped turning on
often found cold joint on the coil of power relay and on transformer near of flyback.+B pin of flyback
Apr 27, 2010 | Hitachi 55FX48B 55" Rear Projection...
My power shuts off on my tv
I don't know what model you have but, mine is a 50v715 and it did the same thing. It turned out it was the lamp. So you might just try changing the lamp. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
I can't find upgrade cards for hitachi 57F59 projection tv
I have a hitachi 57f59a projection tv. I had lighting storm and shut tv off and power was out and when it came back on i turned tv on now my hdmi port on tv doesnt work. any help please
Jun 15, 2009 | Hitachi 57F59 57" HDTV
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
Hitachi 46 in. projection tv - no power
Off the cuff it's about time for a new Tv... But give me the model number and I'll try my best.
Bill
Apr 20, 2008 | Televison & Video
Power light doesn't shut off.
You're right. It's not only a led problem. Efective. the tv doesn't shutt off due to defective relay S901 in primary power supply. It's a 5 volts ordinary relay, replace it and it'll be fine.
Oct 19, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
