Question about Panasonic Televison & Video
My Panasonic smart tv had a thin blue line running down the middle of the screen earlier today. When a tv show was playing the right side of the blue line was fuzzy. Tonight I came home and now when I turn on the tv, the screen is light grey. I am unable to do anything. Example, channels, input, volume. The tv is not responding at all. What happened and can this be fixed?
    Top Expert:
  • Panasonic Master
  • 74,459 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Mar 28, 2015
  • 4234 Answers
SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Posted on Aug 29, 2008
  • 223 Answers
SOURCE: Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Posted on Oct 05, 2008
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
  • 1583 Answers
SOURCE: thin blue line down middle of screen
The red line driver at that point isn't working or there is a bad connection to the panel for that line. (I assume the intensity and hue of the cyan line varies witht the picture). What type of screen is it? Plasma or LCD? The following is for LCDs and may not apply to plasma panels. (I haven't had to fix those yet.)
Once in a while you can solve the problem on an LCD by gently massaging the connector to the display panel edge at the bad spot, although there is a risk of causing other lines to drop out. I once fixed an LCD that had a hair caught between the elastomeric connector and the display glass, but if that were the culprit in your case, you'd probably be missing more than one line. It could also be a problem with the driver chip for that line.
Be very careful about tearing into the LCD. The connections are very delicate, the fluorescent backlight tubes are glass and have mercury inside, and the potential for electrostatic discharge damage is always a concern. It's easy to cause more problems than you fix when you get into the connections, although those can usually be reversed with patience and steady hands. The worst case is a misalignment that would mess up your color registration (color drive going to the wrong line). Most panels have a sticker inside warning against removing the driver electronics. It's there for a good reason.
If I've scared you off, or if the connector massage doesn't work, there are companies like Moniserv that specialize in repairing LCDs. They have the equipment and dust-free facilities needed to repair bad panel drivers.
Posted on Mar 23, 2009
Raditronic
  • 196 Answers
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
Posted on Apr 22, 2010
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Thin blue line on right side of TV. From top to bottom.
No, you should have the screen looked at.... it doesnt cost much but its better then buying a new T.V.
Nov 29, 2011 | Sharp Televison & Video
Thin blue vertical line left of middle on screen
Sounds like a faulty Plasma Display Panel.
Contact Panasonic and find out if it is still covered under warranty.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
May 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Coloured lines down the right side of screen
if the lines extend top to bottom and are thin, then the LCD panel is most likely defective.
Oct 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Right half of screen black with thin blue line top to bottom about another line inch over another thin line starting blue then red getting thiner to bottom
This is a very common problem with this Panasonic set where half the right side is bad and the other half is good. This has been traced to a general plasma panel defect in the manufacturing precess. The panel lasts only about 1.5 years and they go bad. The only solution is to replace the plasma panel. The charges for the cost and labor will double the original prize of the TV set.Good luck.
Oct 27, 2009 | Panasonic TH-42PX60U Television
Red blue and green not lined up
56 inch panasonic tv has blue yellow lines running up and down on right side
Apr 09, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a samsung lcd tv model LE32R41BD, 2 thin blue lines have appeared roughly in the middle of the TV running top to bottom, they are more pronounced at the top, they look almost as if they have been...
you have maybe black lines in picture common on some LCD tv this could be pixel or bad board depending on what side the lines are closest too!
Mar 12, 2008 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
