Question about Vector Camping, Backpacking & Hiking
My vector 156 spotlight won't burn after charging for 4 hours
  • 3,519 Answers
Hi Stephen:
3 possibles that I can think of:
1) Burnt out bulb
2) Battery no good
3) On/Off switch or internal wire not working.
Posted on Mar 28, 2015
SOURCE: Vector power on board high intensity spotlight
Had the exact same problem. Checked the battery and discovered the red lead was off the battery. That's all it was. Works fine now.
Posted on Jun 27, 2009
  • 973 Answers
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
CarlGlas
  • 283 Answers
SOURCE: Vector 2M Pwr Spotlight replacement bulb
It takes a H3 bulb which is available at most parts stores and Wal*Mart stores in the automotive section.
Posted on Jul 29, 2010
  • 156 Answers
SOURCE: I need to know where I can purchase a charger for my vector spotlight mod.156
Vector is made by black and decker. you should be able to get a replacement from them. possible there is a service center close to you to get one from. http://www.blackanddecker.com/Service-Centers.aspx
Posted on Dec 28, 2011
  • 117 Answers
SOURCE: WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Posted on Mar 29, 2012
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
I replaced the battery in mine(coleman powermate) for 10 bucks but you have to be careful in how you disassemble it and put it back together. Batteries sulfate after awhile like a car battery.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
The spotlight/flashlight battery may have failed as a result of being unused and not charged periodically.
Dec 28, 2011 | Vector 1 Million Rechargeable Spotlight
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
Replaced battery in vector 139bw 3 mil candle power. single and double beam not working. How long does it have to charge? Where do I get bulbs for this modle?
You can get the bulbs fron Black and Decker, they service and repair all Vector products.since they were bought out in 2006. www.dewaltservicenet.com You could also have a defective battery or charger, it should take about 10-12 hours to fully charge.
May 15, 2010 | Vector 3 Million Candlepower Rechargeable...
What is the recharge time for a 3million candle power vector model vec139br. batteries are fairly new
You should charge it for at least 10-12 hours, but not any more than that or you will overcharge the battery.
Feb 12, 2010 | Vector 3 Million Candlepower Rechargeable...
It has been charging for days, but only the red & yellow lights come on. Shouldn't the green light shine when charged?
The battery is dead, a usual full charge for your sealed lead-acid battery takes only 10-12 hours. You can purchase a new battery from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69415&tid=15522
Feb 12, 2010 | Vector 1 Million Rechargeable Spotlight
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
299 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
