Question about Garden
When I try to engage my blades my mower dies - Garden
  • 3,519 Answers
Hi Glen:
Several possible problems.
- SAFETY FIRST! Make sure the motor is OFF and then check the blades and belts to make sure they are all free to move. Could be something is jammed or a blade is bent.
- Ask yourself what happened immediately before the problem became evident. That should provide the lead to the solution.
- There should be a safety interlock that stops the mower from engaging if no one is in the operator's seat. Check to see that it is working properly.
Let us know what you find.
Then we'll all go kill grass.
Posted on Mar 28, 2015
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
What would make my mower try to die w/blades engaged?
There are safty switches install on the seat. If you get up off the seat it will shut shut off. You need to to disengage the blades to get off the machine and leave it running. You may also have an issue with the switch setting. Lift up the seat and look for a switch trigger.
hpoe this helps...
May 01, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Mower dies when put in gear or blades engaged
check the safety switches try and bypass them one at a time to find the bad one
Apr 20, 2012 | Garden
Dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
May 18, 2009 | Garden
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
