Question about Candy Dryers
I have a candy grand autodry tumble dryer. The drum still turns but I have a glunking noise when it goes around. Any ideas what this could be please.
  • Candy Master
  • 2,345 Answers
Broken wheel that the drum rides on most likely. or a partially broken drive belt.
Posted on Mar 28, 2015
  • Anonymous Mar 28, 2015
    Do u know how to access these parts on tumble dryer as my husband have taken the top off but can't get into it only can see the drum. Thanks
  • robert Mar 28, 2015
    generally you take the front off to access the drum. remove control panel, then the front. should not be that hard. try a youtube.com search for you make/model and see if there is a video post showing you how. or try appliancepartspros.com or repairclinic.com for a similar video.
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
  • 1122 Answers
SOURCE: how to change a drive belt on a candy CDC266 tumble dryer
don't know what make you have but if you go to sears .com click on parts put in your model number(inside dryer door)you will find a break down of everything you need to know,let me know how you do-mike
Posted on Oct 12, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "Straight-Forward answers, quick - ace!"
SOURCE: How do I use the
Yes - drum revolves around rack. Shouldn't tumble! Insert the dryer rack inside the dryer drum. You must line up the wire on the back of the rack with the ledge of the inner dryer panel. Front of rack tucks into or above lint trap
Read more: Instructions for a Whirlpool Duet Front Load Dryer Rack W10121663 ' eHow.com http://www.ehow.com/how_7584115_instructions-load-dryer-rack-w10121663.html#ixzz1IZICXg1X
Posted on Apr 04, 2011
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
I have a candy tumble dryer. The drum still turns and have changed the all in one unit of the heater and thermostat. However still no heat any ideas please
is the blower blowing? are u getting a full 220 at the outlet? in some machines if u only get half or 110 volts u may have enough power to run motor but not run the heating which takes a full 220, also if ur motor has a bad winding or ur not getting full power at outlet, may also wannt to check terminal block on dryer
Jan 27, 2015 | Candy Dryers
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
Have a Candy Tumble dryer which is about 15 years old (model C57). Worked perfectly for all these years but now pilot light goes on and drum does not turn. What could it be?
Hi usually you will need to take the back/front of and you will find a broken belt replace if broken if it's come off put back on. Regards billy
Feb 24, 2011 | Candy Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Screeching Drum
My machine did exactly the same thing until the belt snapped - and it's a very painful noise!! I'm about to replace my belt and if this solves the problem I'll let you know.
Dec 15, 2008 | Candy CDC266 Dryer
Candy condensor tumble dryer cc23ox
It bee cheaper replacing it as is very comon on these that the drum fails...
Nov 27, 2007 | Candy CDC266 Dryer
Dryers Logo
145 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
