Question about Tablets & eReaders
Do I need to replace a battery or adaptor for tar us tablet that won't charge unless I move cord plug until it will
    New Friend:
    Problem Solver:
  • 5 Answers
Change the adaptor probably a broken wire inside.
Posted on Mar 28, 2015
    Master:
  • 996 Answers
U should change adaptor & its wire
Can I buy a power cord that charges while you are using the tablet?
all tablets can charge while you are using them, on rare occasion the battery will completely discharge and will need to be charged to the minimum before operating the tablet.
Feb 06, 2016 | Hipstreet Flare 2 9 inch Tablet with 8GB...
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Jun 27, 2015 | Tablets & eReaders
Do I need to replace a battery or adaptor for tar us tablet that won't charge unless I move cord plug until .
if you have to "wiggle " the end of the charger where it enters the tablet then its the charging port on the tablet itself that needs re soldering or changed. check the charger by plugging it into some thing else with the same end on ( phone etc ) to make sure its not the charger end. if it works fine then you need to change the port on the table.
May 24, 2015 | Tablets & eReaders
I tried powering up my tablet but it doesn't power up after many tries with many cords and Sears won't take it back. What is wrong?
Hi! I will try to assist you:
1. Make sure the battery is charged enough for the tablet to power on or (if it is not) if you can charge it. An easy way to do thisa is to plug in a charger and see if it indicates that it charges.
If it does not charge, then:
a) The battery is faulty or
b) Something is wrong with the adaptor or the "charge-circuit"
In order for a) and second part of b) to be checked, your tablet needs to be opened!
2. If it charges, then it might be the power button. Try to press it hard enough (try not to break it though) in order to make sure it is not a little bit broken or moved. If still nothing happens then your tablet has to be opened!
3. The screen might be faulty as well.
4. If it is none of the above, then it might be the mainboard. In order to make sure it is not the mainboard, you would need to connect it to an external monitor and see if it works with the external one (I think there is no such option in your case, though)
I assume you wish to experiment-check it by yourself. If you just need a new one, then for instance:
1result for maylong universe
Dec 06, 2014 | Maylong Tablets & eReaders
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
Nook tablet will not turn on
Yes, press and hold the power button, for up to 30 seconds, or until the "N" logo appears on the screen.
If it does not, suggestions are that the battery is dead or not charging because the power cord itself is broken or frayed inside the cable and you will need to replace with either a B&N cable or a Micro USB cable.
It could also be the wall charger unit is no longer functioning, and this must be replaced.
I have so far replaced one wall charger and three USB cables, so this is a unnecessary common event with Nook
May 03, 2013 | Barnes & Noble Nook Tablet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER UP WITH THE CORD OR BATTERY DEAD. IS IT THE BATTERY OR CORD THE PROBLEM. MY OTHER LAPTPS WILL STILL POWER UP IF THE BAT IS DEAD, IS THIS NOT TRUE FOR THE...
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Dec 31, 2009 | ASUS R1E-B1 Tablet PC
Acer Travelmate 2200 laptop
Try taking the laptop battery out. You can remove the laptop battery by turning it over, you'll usually see some sliders at the bottom, slide them to the unlock position and you should be able to wedge your battery out. The battery usually comes in a very tall and thin rectangular shape. Once the battery is out, plug the laptop in through the mains power - this may solve your problem, if it does, you'll need a new battery if you wish to use it on the move. If it does not solve your problem, it is either a faulty power adaptor, or a faulty power supply on the motherboard of your laptop. A faulty power adaptor or battery is the best case scenario, as it's the cheapest to buy a replacement (although it's still expensive - $120 worth in the UK roughly). A faulty power supply on the mainboard generally means you'll need a replacement mainboard which is totally uneconomical, especially with the labour cost to fit it professionally. If the battery and power adaptor is not faulty, you might as well scrap it and get a new laptop. Good luck Tina!
Sep 07, 2007 | Acer TravelMate 302XCi Tablet PC
Tablets & eReaders Logo
37 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
