Question about Weslo Cadence G - 40 Treadmill
My weslo treadmill G40 shuts down after awhile. And the motor is extremely hot. After it cools down it will start up. My belt on the motor was loose and I retightened it up. But it still shuts down. The treadmill belt looks good.
    New Friend:
    Problem Solver:
  • 5 Answers
It is overheating. Most motors have some type of fan system to prevent this which could be clogged preventing air flow or could have stopped functioning. If it is simply clogged take compressed air and blow the debris out of it ( this may take a few trys if there is a lot of debris) if it is no longer working you may need a professional to replace it. Also if it is on carpet instead of a hard surface that can impeed airflow as well.
Posted on Mar 28, 2015
    Master:
  • 996 Answers
U hv overtighted the belt,,,loose it
When i step on the treadmill it doesn't move
check your trad ill motor and walking belt & drive belt
Nov 24, 2015 | Weslo Cadence G40 Treadmill
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Starts up but imediatly shut down
see the video and proceed according. However if the problem persist after you did. TIME to replace the old deck board. God bless you
Mar 23, 2013 | Weslo Cadence G40 Treadmill
Weslo cadence g40 stops for no reason
you must LUBE THE deck belt by aprox 150 miles. In according with the schedule maintenance,
Please LUBE the deck belt+rollers bearing.
see the video
If the problem persist time to replalce the OLD board deck belt.
God bless you
Jan 22, 2013 | Weslo Cadence G40 Treadmill
I have a Weslo Cadence G - 40 Treadmill and it just stops all the time.
see the video lube the deck belt+ rollers beaaring.
If after you lube and problem remain, time to replace the deck belt board.
God bless you
Jan 11, 2013 | Weslo Exercise & Fitness
Does this treadmill have a incline
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
Lube the motor, rack, pinion and adjust the POT, see the diagram attached., clean it the sensor, and tight the plug well.
God bless you
Oct 16, 2012 | Weslo Cadence G40 Treadmill
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
Hello i have a weslo cadence 260 treadmill,it runs for about 1 minute then stops,the motor stops too,i have to keep tuning it off and on for it to work again,whats the problem with it,would be great if you...
It sounds like you have a worn deck and (or) belt. If the machine runs just fine without being on it but stops when someone is on it, then it sounds like a worn belt/deck.
The friction under the belt is so great that it overworks the motor to the point where it shuts itself down. The surface needs to be slick and smooth for the motor to work the least amount.
You could try to put some silicone under the walking belt and see if it helps. It really depends on how many miles are on it.
Feb 24, 2011 | Cadence Weslo 620/630 Treadmill Walking...
Shuts down after running a few minutes
hi when you mean shuts down it that the power or just the belt, if everything including the power turns off then check the trip switch on the front of your treadmill, and if you are using an extention wire on a roll, please unroll the whole thing that can cause a short. and if you can smell any burning thats a sign that the motor and belt are either too tight and on they way out.
Nov 12, 2010 | Cadence Weslo 620/630 Treadmill Walking...
Weslo Cadence G - 40 Treadmill Logo
135 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
