Question about Garden
Got a 8n tractor runs fine when idling not smoking and no noise could a hydraulic pump going bad make it sound like it's the engine
  • 3,519 Answers
Hi Kenny:
Had one of these on the farm when I was a kid.
Can you expand your question please.
Are the hydraulics working properly?
Does the engine give problems at higher RPM?
We'll do what we can to help once we understand the problem.
Keep that old iron running!
Posted on Mar 28, 2015
SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Posted on Mar 21, 2009
  • 218 Answers
SOURCE: Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
Posted on Jul 09, 2009
  • 2841 Answers
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Posted on Sep 01, 2009
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Posted on Nov 09, 2009
  • 302 Answers
SOURCE: Model Number 917272670. 17.5 HP Craftsman Lawn
Sounds like coil is giving trouble after getting warm poss need to replace coil.
Posted on Jun 30, 2010
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Brake pedal hard with engine running, same as engine off
Check fluid levels in your power steering/brake reservoirs and look for hydraulic fluid leaks in the power steering and brake lines. Could be a bad power steering pump too. Your owners manual should show positions of hydraulic reservoirs.
Jun 15, 2015 | 2004 Cadillac CTS Sedan
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
8N rpms keep falling
I run one number hotter plugs in my N tractors as they tend to foul plugs.
Glad it was a simple fix.
Apr 28, 2010 | Ford 8N Tractor
I have a Ford 8n with a new battery, solenoid and starter switch. The tractor was running fine, I shut it off for a few minutes while changing the hydraulic oil and when I turned the key on I had no...
8N's are positive ground negative run...hence the negative wire to the battery. Try jumping the starter solenoid and see if you have a bad solenoid. A second answer could be in your battery. You have a 6 volt battery so be sure to check the charge on the battery.
Apr 26, 2010 | Ford 8N Tractor
Ford 8n gets hot, may need to be timed,Step by step needed.
This is everything that i know that will make an 8N run hot...a stopped up radiator(inside)..a radiator that is filled with debris in the cooling fins..a bad thermostat(located in the upper radiator hose..if it has one).....a stopped up block..bent fan blades...fan shroud missing..a bad water pump..the fan belt slipping on the water pump ..a blown head gasket..low coolant..i hope this will help and one of them should fix it ..if not...please write me back
Jul 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9n 3 point will not lift
Hey Chris..my name is Keith..and i restore 9N's,2N's and 8N's ..and i can help you with your hydraulic problem...the most probable cause is the hydraulic safety relief valve and i would change that 1st..the part number for it is..8N-638..and they cost about 25 dollars..and to change it..you either jack up the rear axle or you part the tractor down hill..so the hydraulic fluid goes to the front..and then you open up the side cover..that has the dip stick in it and unscrew the Safety relief valve from the hydraulic pump9located on the back side of the pump)..and install a new one..and have plenty of rags..because it is a mess job..and if you dont want to opent that cover again..i would replace the hydraulic control valve..part number 9N-640..is costs about 35 dollars and its on the back side of the pump also..and dont forget to get a new cover gasket and that part number is 9N-4131 and it costs about 1 dollar..i hope this has helped..if not write me back and we will get into the hard stuff on the hydraulic system
Mar 15, 2009 | Ford Garden
Ticking noise from engine
You might have a bad hydraulic valve lifter (assuming this engine has them)... you could try an aftermarket product designed to unstick valve lifters.... any auto parts store carries them.
Mar 04, 2009 | 1999 Daewoo Leganza
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
