Question about Dyson Vacuums
My Dyson turbo head stopped spinning, so I took it apart, all except for the red pop out filter on one side. It looks like there is a fan inside, but that is not turning. Should this fan spin, and how do i get the plastic cover off? (The other side just popped off easily)
  • rdjagger Jul 22, 2015
    the fan should spin.
    Top Expert:
  • Dyson Master
  • 10,875 Answers
Well now you voided any warranty,there is a problem with the switches,dyson might of fixed it b4,not now
Posted on Jul 22, 2015
CorvetteKing
  • 108 Answers
SOURCE: Brush part not spinning
The hoover savvys have a reset button on the top of the hood, its to keep from destroying the belt. Simply press that button and the brush should start to turn.
If this does not solve the problem it is more than likely the belt (rubber band thingy :) ) in this case pull the bottom plate off again, but this time lift the brush out and slide it to the side and out from the belt. Then look inside the machine and get the belt off of the motor drive gear. Once the belt is out turn it inside out and make sure the teeth to the belt are all there. ( if they are not there will be burn marks.) If it is missing teeth simply replace that belt and you're back in business.
If it is not the reset and it is not the belt, some of those machines had bad switches in the handle. You will find that there is a circut board in the top handle which sends power to the vaccum motor but not the brushroller motor making it seem as if everything is running just fine. You will not be able to buy just the circut board, they come as an assembly and include the whole handle. Unfortunately there is no good way for someone unexperienced to tell wether there is power to the brushroller motor or not. In this case a Hoover service center would be able to assist you though you may end up paying a small labor fee.
Posted on Jun 05, 2009
  • 83 Answers
SOURCE: Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Posted on Jul 30, 2009
VacuumRepair
  • 438 Answers
SOURCE: HooverSpin Scrub and the brushes always stop spinning.
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Posted on Mar 21, 2010
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My dyson dc25 which I
    Sorry to hear you're having difficulties with your DC25. If you haven't tried this already, try pushing the filter firmly into place until you hear an audible click. This should stop the filter popping out of place.
    However, if you're still having problems, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks on the phone, which should hopefully resolve this issue.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Jun 08, 2011
    Turbo head has stopped spinning
    Hi Fay, it's Jack at Dyson.
    If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar.
    It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions:
    If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
    Mar 05, 2016 | Dyson DC39 Multi floor canister vacuum...
    The rotating brushes on my floor setting keep stopping on carpet - even though nothing is clogging it. I have to turn my vacuum off and then back on to get it to start spinning again.
    There are two things that cause this.
    1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
    2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
    If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
    Keith from Dyson Repairs North Shore Auckland
    Sep 24, 2014 | Dyson DC29 Animal Vacuum
    Dyson DC23 canister vacuum turbine head attachment stops spinning.
    bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
    May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
    Dyson power head stops but can be started immediatly
    Just had the same problem. Took apart whole power head to look for broken wire and found none. If you see part way up the hose there is a coller with 4 torx screws holding together. This collar is a swivel that allows the hose to spin without twisting or kinking. Take the 4 screws out and open up. You will see 3 contacts that look like fingers that rub on 3 mating steel rings. Wipe the tips of the fingers and wipe clean the rings. Gently bend the fingers out wards so that they apply more pressure to the steel rings. Reassemble and try. Should take no more than 15 mins. Worked for me good luck!
    Mar 15, 2014 | Dyson "Stowaway" Canister Vacuum Vacuum
    Power head not working
    Hi, it sounds like your motor is gone. That was the sound i had from my dyson dc07 animal i took it apart and found that the brushes had burnt the armature on the motor. I ordered a new motor and fitted it back together with the help from an espares video. I bought a genuine dyson motor they come in a black box and it is a lot cheaper than buying a new dyson. It was the popping sound that i had .Hope this is of some help to you. Always unplug the hoover when working on it.
    Mar 02, 2014 | Dyson Slim DC18 All Floors HEPA Bagless...
    Dyson DC11 turbo head not spinning - it feels like the selector button has broken inside and is locked to not spin. is there a way to disasembel and maybe glue or fix the selector?
    Hi Andrew, it's Jack at Dyson.
    With the exception of the sole plate and brush bar, the Turbine head is manufactured as a complete assembly. We wouldn't recommend attempting to dismantle it as we can't guarantee this won't cause damage. You might want to take a look at our Support guide, as it may be possible to resolve the issue with some simple troubleshooting:
    http://content.dyson.com/support/help.asp?article=342&product=DC11-SY-ALLERGY
    If you would like further advice after giving this a try, you can reach our experts directly by emailing askdysonUS@dyson.com
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    Aug 03, 2013 | Dyson DC11 All Floors Bagless Canister...
    My bristles wont spin
    Hi Maggie,
    Alec from VacuumSpot here. There are 3 reasons why the brushes might stop.
    The first and easiest is to check if the turbo head is set to carpet - there is a selector on the side that also acts as a bit of a filter. It's an obvious one but sometimes overlooked.
    The second and cause is also easy to fix is if your filters are worn or dirty. You wouldn't notice a marginal drop in suction from day to day but over a year the filters do reduce in performance. Once they wear (I know they are meant to be lifetime but they are not) they just need to be replaced. For the best performance just buy new DC11 filters every couple of years they are cheap and it's worth it.
    The other thing can be that the roller brush is in need of a good clean. Remove the base plate and pull the rollers out to either side, you will find they simply slip off the shaft with a bit of effort. Clean inside the brushes and also the shaft. Normally you will find a bunch of hair and fluff inside which can slow the roller down.
    If you clean this and also make sure you have clean filters and the roller still doesn't spin unfortunately the bearings in the head are wearing and the head needs to be replaced as Dyson hides the bearings in a sealed casing forcing you to replace rather than repair.
    I hope this helps you out.
    Regards
    Alec
    Dec 08, 2012 | Dyson DC11 All Floors Bagless Canister...
    Turbine head of my Dyson DC08 does not spin
    Jan 24, 2010 | Dyson DC08 Cylinder Bagless Canister...
    Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
    Vaccumed up water with Dyson DC17. Turbo? is now stopped up
    You cannot clean out the ports in the turbo. I tried and tried! Broke down and took it in. Needed a whole new vortex/canister assembly. There was a known warranty issue about the gasket at the bottom of the canister causing issues with clogs in the turbo/vortex area. Of course mine was out of warranty; also got a new HEPA filter; about $100. This is where I took it and they were very knowledgable about Dyson's.
    http://www.aaavacs.com/
    Mar 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    104 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
