Question about Video Game Consoles & Games
I had just recently purchased a playstation 4 and connected it to the hdmi port. I cannot seem to get the video to pull up on the tv. Do I need to adjust settings?
  • Sam H
    Sam H Mar 28, 2015
    Testimonial: "I am on the proper input but all I get is a black screen. Tried a different cord but still no luck. Could it be that the resolution is to high for the tv??
    Genius:
  • 2,653 Answers
On the TV press input , using the up down keys select HDMI then press OK.
Posted on Mar 28, 2015
Testimonial: "I am on the proper input but all I get is a black screen. Tried a different cord but still no luck. Could it be that the resolution is to high for the tv??"
Just purchased alexa fire stick, have only 1 hdmi port on TV, what to do?
If your TV is an older model and only has a couple HDMI ports, but you have several media sources, such as Blu-ray players or video game consoles, an HDMI switcher is exactly what you need. Connect all the media sources to the HDMI switch box via anHDMI cable and then connect the HDMI switcher to the TV.
Jul 30, 2017 | Televison & Video
How do you connect a ps4 to the tv
  1. Plug the included HDMI cable into the HDMI Out port of the PlayStation 4.
  2. Connect the other end of the HDMI cable into an available HDMI In port on your TV.
Jun 28, 2015 | PS4 Video Game Consoles & Games
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
Hi I have recently purchased a HD TV I connected my playstation to it via HD cable and I cant seem to get it to work on my old TV now can you please help? Kind regards Jackie
Yes,Go to your PS3 settings, and go to your videooutput settings, there you should be able to selext AV cable or HDMI cable. If not, let me know!
Grtz!
Sep 28, 2009 | Sony Playstation 3 (PS3) Console
No picture, only sound through HDMI port
You have the video [yellow cord] on the wrong rca jack. Or a bad video cord. Should be easy to fix.
Mar 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Playstation 3 on Sanyo Large Screen HD DT
It would be better if you went diretly threw a video source on the TV. Rn the wires from the PS3 to the tv and then select the source that it is connected to
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
