Question about Breville Vitesse VIN118 2000 W Steam Iron
How to reduce the ingredients for bread packet mix. I made the recipe and it overflowed the machine and tripped my power
I used the recipe on the packet, and for a small loaf, but it was still too large for my machine. It popped the lid of the machine and tripped my trip switch. The recipe is for 480ml water, 600g bread mix and 1 tsp yeast
    New Friend:
  • 20 Answers
You can reduce it proportionally. For example, if you only want 1/2 of the bread, you will have a 1:2 ratio. 240:480, 300:600, 1/2:1
Posted on Mar 28, 2015
Rotary iron kenwood used
If there are wires connected to the foot pedal, control is electrical, not mechanical. Contact eBay directly for resolution.
May 09, 2017 | Irons
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Oct 20, 2013 | Rowenta DG-980 Iron
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
I have a steamfast steamer that is tripping the circuit breaker. Any ideas why?
you check the wiring inside which may have short circuit, then the connector for filament which get short.
Nov 28, 2012 | Steam Fast SF-661 Iron
I have a Bosch b52l iron, when i turn on the steam button, it cuts off the power, what could it be
It could be the iron itself (it may have a short circuit in it) and the circuit breaker trips when the steam switch is turned on.
Option 1)
Another option is that the entire circuit that that circuit breaker is controlling is overloaded. What other outlets / applicances / lights are disabled when that circuit breaker trips? You may have to iron only when those other applicances on that circuit are not being used.
Option 2a) Your outlet may be damaged and causing your circuit breaker to trip when the high current STEAM setting is set.
- OR -
Option 2b) the circuit breaker is damaged and is tripping too easily. Only replace with a similarly sized circuit breaker (15 amp lis likely but is says right on the breaker).
Try the solutions in that order.
-Mark
Please rate me..
May 07, 2011 | Bosch Irons
Trips circuit breaker after 10 minutes of use
This iron is 1500 watts. On a 120 volt breaker, that's about 12.5 amps. Check to see what else is on this breaker. A 1500 watt space heater or a washing machine combined with this iron will pop a 15 or 20 amp breaker.
Mar 03, 2011 | Rowenta Professional DX8800 Iron
How do I clean the calicum deposits out the inside of the iron
go to the hgardware stor and get cleaner called clr
fill your resivoir and let it set over night
make sure you use a 50 50 mix with warm water
by morning your machine will be spotless
Oct 26, 2009 | Euro-Pro Shark GI490 Iron
Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Sep 07, 2009 | Philips HI-296 Iron
Breville Vitesse VIN118 2000 W Steam Iron Logo
94 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
