Question about Kenmore Sewing Machines
The feed dogs on my kenmore 1278191 are only pulling the fabric backwards and I don't know how to fix it. I already oiled and cleaned it
    Habit-Forming:
  • 187 Answers
Try reverse at high speed, without thread; to see if it will free up the mechanism.
Posted on Mar 28, 2015
Janome Jem Silver 662 will only sew backwards. How do I adjust it so it will feed fabric correctly?
1) Check the feed dog pressure adjustment. 2) Check the feeding mechanism at the bottom. It may be too low to feed your cloth.
Feb 03, 2015 | Janome Jem Silver 662 Mechanical Sewing...
I have cleaned and oiled my sewing machine according to book instructions. Before and after, it doesn't want to pull the material. Seems to want to sew in one spot. Can you help me know what to do?
check the feed dogs in the needle plate area to see if there up or down
look in the book and find where the lever is to change the position of the feed dogs. when there up the fabric will move, but when there down it stays in one place
Sep 10, 2011 | Kenmore Sewing Machines
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
I have 385 old model. my cloth is not moving.i have to pull against me to keep going.if i don't pull then it keeps stitching at one spot.i don't know if its feed dog lever is gone bad or something else is...
Difficult to say. Obviously, if you have the stitch length set high enough (at least 2.5 or higher) so the feed dogs should pull the fabric through the machine, then something is definitely off. If it were a purely mechanical machine, sometimes old oil has dried and "glues" the mechanical movement together so the parts seize. This happens in the older mechanical machines when they are not treated to regular cleaning and oiling. If this is the case, your machine could benefit from a professional cleaning and oiling. However, if a part is worn or broken, parts replacement could be required.
The other thing to consider is what kind of fabric you are sewing. If it is light-weight fabric like chiffon, sometimes the presser foot pressure adjustment needs to be increased. This applies more pressure between the presser foot and feed dogs so the feed dogs can grip the fabric better. Try stitching on different weights of fabric and see if there is any difference. Most machines do have a pressure adjustment. You just need to know where to look for it on your particular model. It's usually placed at the top left side of the machine and could be a "plunger" type, a screw that is tightened or loosened, or on newer machines, a dial. On older machines, sometimes it is under the top cover at the top of the presser foot bar.
What Pressure Adjustment on Sewing Machine
Aaaak! Is this a sewing machine or serger? This diagram may help:
https://www.pinterest.com/pin/515451119836350686
or the manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwiyptPa_Y7YAhUE32MKHXU7AVoQFghOMAY&url=http%3A%2F%2Fwww.managemylife.com%2Fmmh%2Flis_pdf%2FOWNM%2FL0306427.pdf&usg=AOvVaw3vM9XD3zy4mkPrWoKcHNQa
Dec 16, 2017 | Kenmore 16622 Mechanical Sewing Machine
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
Kenmore Sewing machine model 385.1884180, feed dog quit pulling
A common malady with Kenmore sewing machines. The feed system needs lubrication and perhaps some solvent cleaning to loosen sticky pivot points. If you are adventurous, you could take off the bottom and oil all the moving parts. Or take it to a service person.
Jun 12, 2009 | Kenmore Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
hi there check feed dogs are up not down mary h
e
Dec 28, 2008 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
77 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
