My ignis Bella 60 front load washing machine inner tub has developed sideways play . It rubs against sides during cycle with soft rubbing sound and stucks
    Sergeant:
    Champion:
  • 242 Answers
At the back of the washing machine is an inspection plate not large
turn off the power and pull the plug from the wall and turn it from the rear and see what is happening
Posted on Mar 28, 2015
BIKER T
  • 909 Answers
SOURCE: spinning cycle sounds like it is rubbing against something
I take it there is a loud noise while in the spin mode.
That normally means your bearings x2 and seal need to be replaced. Truthfully it needs to be done by an appliance tech.
Posted on May 17, 2010
aborcass
  • 2651 Answers
SOURCE: worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Posted on Apr 15, 2008
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Front Load Washer Drive Belt Keeps rubbing up against Tub
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
  • 11 Answers
SOURCE: during wash cycle, makes a squeaking sound and is
Posted on Nov 30, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
During the spin cycle it sounds like the drum is about to come out of the machine and there are little grey plastic pieces in the clothing.
Sound like the basket has broken away from the spinning support coming of the back of inner drum, Gray plastic is the front ring the inner tub is now rubbing on. This has been making noise for a while. Phil 1-800-559-1411 www.phils.com any help I can give you.
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Loud noise during spin cycle, finding shreded plastic in drum.
Sounds like the support arms have failed and the wash drum is now rubbing against the outer tub. It is a expensive repair. Get a few estimates before deciding whether to repair or to replace. Hope this helps.
Nov 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Abnormal shaking during spin cycle
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Worn outer tub
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
Kenmore Elite he3T front load, bought 2004
I'm going from memory on the "H F" code: If it stops during a filling cycle, it's probably the small rubber hose running between the pressure switch and the bottom of the tub. Mine had a small hole rubbed in it as a result of it rubbing on the counterweight on the back of the tub assembly. I replaced the hose with some vacuum hose I purchase at a car parts store that had the same inner diameter. I also made sure the hose wasn't rubbing the counter weight when I reinstalled it.
Jan 02, 2008 | Kenmore 46462 Front Load Washer
Noise
High probability that an object, that had escaped notice during loading of clothes, has been "tossed" over board the wash tub into the outer tub. Most washing machines are constructed this way (two tubs, one move-able, one stationary) to prevent this object toss, but somehow they still get tossed. Solution is to remove the object and methods vary from simple (use magnet snake retriever if object is magnetic) or use mechanical snake retriever (has tiny pliers at far end of wire) to extreme by removing inner tub.
Dec 24, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
