Question about Avanti Convection Oven with 2 Burner Cooktop - White
HOW TO CHANGE FUSE - Avanti Convection Oven with 2 Burner Cooktop - White
    Sergeant:
    Champion:
  • 242 Answers
You should not touch electricity
too much can go wrong
call someone qualified
Posted on Mar 28, 2015
I have whirlpool induction cooktop and it does nothing. I have current and nothing. I was wondering if the fuse could be bad. The fuse is 30A/250 an couldn't find one so I tried 20A/50 not
You will definitely need the correct fuse. Get someone competent with a meter to test the circuits. Test the original fuse before going further to see if it is OK or not.
Nov 15, 2014 | Whirlpool GCI3061XB 30" Induction Cooktop...
Cooktop short circuits the electrical fuse when plugged in
Try removing parts or connections until the fuse does not blow.
With a gas hob, you are limited to a short in the ignition system.
As the igniter has failed try removing it. This should solve the fuse problem, if it doesn't, look for a short in the wiring.
Jan 09, 2012 | Thermador 46 in. SGSX456 Gas Cooktop
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
Oven wont shut off
Fuse won't let it shut off? That doesn't make sense. A fuse is made to connect something not disconnect something. I don't know how much you paid that repair man but I would probably call another to verify the diagnosis.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Wolf Range 30 in. SCB30C Gas Cooktop
What does EO means on LED of a induction cooker
i have longer induction , problem is EO error on the display..
i changed(IGBT,Fuse,Capasiter) what i do?
Jul 03, 2009 | Cooktops
Can fuse be blown?
youl have to pukk out the unit and check the connection/installaiton. youll need to determine if you have proper voltage going to machine. ther if no fuse on the machine, more than like a power supply issue
Oct 30, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Chef Electric Hotplates
Never...ever change the fuse rating upward on an existing circuit to accomodate a new appliance. The fuse is a protective device designed to limit current to the level the wiring can safely handle. There is a strong possibility of fire at some point!!!!
If you are rewiring, most places require up to 30 amps for cooktop wiring anyway. Use #10 copper wire for that purpose. If you are doing this yourself, make all connections tight and install all grounds.
Jun 14, 2008 | Cooktops
On Light Won't go off on cooktop
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Jan 29, 2008 | Cooktops
Avanti Convection Oven with 2 Burner Cooktop - White Logo
79 people viewed this question
Top Avanti Cooktops Experts
Paul Carew
Are you an Avanti Cooktop Expert? Answer questions, earn points and help others
