Question about Hoover Vacuums
How do you replace the motor on a hoover max extract 60 pro model number FH50230?
SOURCE: fairly new Platinum series Hoover Max extract wont turn on
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Posted on Aug 09, 2010
  • 240 Answers
SOURCE: My Hoover SteamVac Max Extract 77's dirty water
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Posted on Jan 22, 2011
  • 240 Answers
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Posted on Jan 28, 2011
aquaman987
  • 927 Answers
SOURCE: the brushes on buttom dont spin already exchanged
Is there a switch for TOOLS or VACUUM?
Posted on Feb 03, 2011
eugbug
  • 479 Answers
SOURCE: Fairly new Hoover max extract won.t turn on.?
If you are lucky the cord may be broken on the vacuum or the cable may be loose in the plug. and it's not the motor which is burnt out.
Have a look at these tips, they apply to power tools but are valid for home appliances also:
http://www.fixya.com/support/r9189659-power_tools_not_starting_up
Posted on Jun 07, 2011
My Hoover max extract 77 will not turn on why
The power switch's in those machines are crap. You can take the handle assembly out and replace switch with a new one. When took apart check voltage at switch to make sure you have power there. If no power, replace cord
Jul 24, 2015 | Hoover Vacuums
Hoover max extract 77 manual
Hi! Follow the link below to view the manual for the FH50240. Hope this helps!
http://hoover.com/file/611/
Jul 19, 2014 | Hoover Max Extract 77 Carpet Cleaner -...
Hoover max extract 77 water tank leaking
Remove the little black plastic plug on the bottom of tank (has a metal spring around it), that is where it is leaking. Wrap Teflon (pipe tape) around it and the spring. Replace black plug. Not a permanent fix, but can help if you are on a bind. It worked for me.
Sep 09, 2012 | Hoover F5505 SteamVac Spot Vacuum
I can't get my Hoover max extract platinum to
First this is complicated to diagnose with it not being in front of me. Where i would start if i were you is make sure it is all together correctly or simply take it apart and put it back together make sure all is there and seated proper and try it again also if you feel no resistance or hear no clicking sound from the on switch it just may be bad.
Apr 08, 2012 | Hoover Vacuums
I cant get the brushes to spin on my hoover max extract carpet cleaner
Jan 28, 2011 | Hoover Vacuums
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
Fairly new Platinum series Hoover Max extract wont turn on
Feb 18, 2010 | Vacuums
Vacuums Logo
71 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
