Question about Samsung 6300 Series UN46F6300AF 46" LED Smart TV 1920x1080, 120 Hz, HDTV
Samsung un46f6300 sound cuts in and out - Samsung 6300 Series UN46F6300AF 46" LED Smart TV 1920x1080, 120 Hz, HDTV
  • Samsung Master
  • 681 Answers
Please check the speakers.
Posted on Jun 13, 2015
Samsung led un46f6300 top half has is darker than bottom
back light is bad need open the display and replace led strips
Feb 24, 2017 | Samsung UN46F6300AFXZA - UN46F6300AF 46...
Samsung LN-S3251D intermittent sound problem
Try to check the connection from your HD reciever it could be a loose signal from the reciever that why the sounds cut out..
Tell me more.
Thanks
Feb 19, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung un46f6300 flickering
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 28, 2016 | Samsung Televison & Video
I have a Samsung UN46F6300 TV and the external sound output has quit working. Would replacing the T-com board most likely fix this problem?
Check the audio settings menu of the TV. May be there would be an option to select the audio output whether you wish use inside speakers or external amplifier. if its there then You have to change the setting to external amp.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 26, 2016 | Samsung Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
I have a Samsung un46f6300 smart tv, and the sound cuts in and out every other second. It happens when I stream videos via youtube, use my blue ray player or any other input devices. Even on the startup...
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Apr 10, 2017 | Samsung Televison & Video
Samsung un46f6300 does not turn on
Does the power on led burn?
If not, check if the power cable is inserted in the wall outlet. Check if the wall outlet has any power, by plugging in a lamp or so. Then check if the power cable is correct inserted in your flat panel TV.
Still no light, perhaps the cable is defect. If you have a power led burning on the TV, try switching it on manually, not by the remote.
To check the remote control, use a smart phone or a digital camera. Hold the front of the remote control in front of the camera lens and while the camera is on, press the on / off button on the remote. Look at the display if from the remote control is coming some light. If not, replace the batteries in the remote control. Or if the remote control is new, perhaps you should put in some batteries?
Jun 02, 2014 | Televison & Video
Samsung hls4676sx/xaa sound cut off and speaker cracks
Sounds like an analog board problem--IIRC this has the audio amp on it.
Mar 05, 2014 | Samsung HLS4676S Television
My samsung tv sound keeps cutting out. I have to
either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
Dec 02, 2009 | Samsung LA40A450 40 in. LCD TV
Picture cuts out and sound delays
Wow, I have the same problem. I have even tried using never used DVDS, it just freezes after a while. I will get small glitches every few minutes. I am calling Samsung tommorow and raising hell, this was a Christmas present and I am embarrased. I also use HDMI and have changed the set up to 720P.
Dec 01, 2007 | Samsung HT-X40 System
Samsung 6300 Series UN46F6300AF 46" LED Smart TV 1920x1080, 120 Hz, HDTV Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
