Question about LG Televison & Video
60PN5700-UA Circuar icon appears at times on screen. What is it for, how do I dismiss it
    Genius:
  • LG Master
  • 2,553 Answers
If its on the top right hand side and flashes twice there is nothing you can do , It is a spool change over signal left over from the old movie days.
Posted on Mar 28, 2015
Lg 60pn5700 plasma tv repair
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 07, 2015 | LG Televison & Video
60PN5700-UA no picture
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Aug 18, 2015 | Televison & Video
How do I unlock the screen rotation
if you use iOS 7 or 8, swipe up from the bottom to bring up the menu. ON the top row of icons, on the farthest right there is an icon with a lock surrounded by a circular line and arrow. Tap this to toggle the rotation lock on and off.
Feb 24, 2015 | Apple iPhone 5c
How do I watch Netflix on my LG 60PN5700?
do believe you need something else like a gameboy or playstation attached to get netflix has to hard hard drive so it can download
Feb 10, 2015 | LG Televison & Video
I have a Samsung Galaxy Ace. When the alarm went off, I pressed the home menu key as I picked the phone up, and was then unable to get to the screen where I could turn the alarm off. After a couple of...
GALAXY ACE-HOW TO TURN ALARM OFF - Hi, you've probably figured it out by now but just for any other new users who are still struggling, here is the answer: Galaxy Ace : When your alarm is going off and you lose the screen option to either snooze or dismiss, simply look in the top left of the phone and you will see the little alarm icon with an exclamation mark on it, on the top bar where the signal strength indicator and the battery icon is. You can scroll your finger down over this top bar and move it down over the top of your current screen, and when the alarm is ringing, the option to either snooze or dismiss the alarm also appears on this pull down screen. Peace at last!! Hope this helps someone.....
May 05, 2011 | Cell Phones
Missing files for recorder and Youtube. How do I reset to factory settings to get all needed files?
If you have deleted the icons for those programs on your desk top, then they may be in your Recycle trash bin. double click on Recycle Bin look for the icon for recorder, right click on recorder and select restore. You really cannot delete the programs from your machine as they are retained in a ROM chip , hard coded into the chip and are loaded each time you cut your machine on. The only thing you can do is delete the icons on the desktop, which are sent to the recycle bin.
To retore the machine to factory settings, there is a small hole just about an inch down from the data plate on the back. Using a pencil point or a straightened paper clip, insert the bject into the hole and hold for about 5 seconds. Your deleted icons are not replaced.
A second method to restore your icon is to click on my computer right click on the recorder, select copy, dismiss my computer, find a blank spot on your desktop and right click on that spot, select paste, and a dos type icon appears as your recorder button. When you cut the machine of and back on the Dos type icon is replaced with a CE type icon.
Dec 07, 2010 | Sylvania G-Netbook
My iphone 3g's touchscreen not responding
hold the on off button down and the button at the bottom of the phone together for 15 seconds till the screen goes blank dont worry if anything comes on the screen then wait a further 5 seconds then swicth the phone on the problem should solved
May 20, 2009 | Apple iPhone Smartphone
Monitor adjustment menu refuses to be dismissed
A temporary solution is to adjust the screen resolution. If you right click on your Desktop, click on Personalise, then Display Settings, you'll be able to alter the resolution. You don't have to actually make the change permanent, just change it and when it asks you if you want to accept it, say no. That's made mine disappear for a while, but I suspect the menu will appear again soon.
Running Check Disk seems to work for a while too, but it's not permanent either.
Someone suggested disconnecting the buttons on the bottom of the screen, but I'm reluctant to try that.
Apr 14, 2009 | Computers & Internet
Random icon and alarm
The orange bell simply means that you've 'missed' your alarm... as in you haven't turned it off before it finished its alarm sequence. If you go to Menu - 'Missed Alerts' it should be shown in there. Click on it and say 'dismiss', the orange bell should disappear and the alarm should return to normal.
Sep 25, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Televison & Video Logo
35 people viewed this question
Computer Repairing
Computer Repairing
