Question about Craftsman Garden
If the ignition switch being removed have anything to do with my craftsman riding lawnmover stalling when I let out the clutch/brake?
    Sergeant:
  • Craftsman Expert
  • 187 Answers
Likely YES. Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
Without the Year and Model numbers we can only assume the machine is say...less than 15 years old. If so the safety system ground circuit runs through the Key switch, as well as the Brake, PTO, Seat, and Reverse switch system. If you have removed the Key switch (ignition switch, same thing) you have altered the Kill system on the machine. This would account for your problem. Exactly how, I cannot specify not knowing what machine you have. they are all wired a bit differently. The principles are the same tho.
Posted on Mar 30, 2015
SOURCE: engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Posted on Feb 12, 2009
SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Posted on Mar 24, 2009
  • 109 Answers
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Posted on Apr 23, 2009
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Model 917.259566 Tractor starts perfectly, but stalls out when the clutch is released. Whats happening?
Most likely your seat safety switch is not working. In order for the engine to run with blade engaged, the operator present switch must be made when the brake is taken off (releasing clutch).
Oct 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 6 year old Craftsman rider, model 27363 w/18.5 HP Briggs engine and 42'' deck. I tried to start but nothing - no click, ammeter doesn't move, hour meter doesn't run. Checked battery, have 12.8...
The start circuit usually only goes through the clutch/brake switch, and the clutch switch. That way it won't start if the clutch isn't depessed (brake on) and the mower deck turned off. You can test for voltage on the s terminal (start) on your switch. then for 12V+ at the clutch brake switch, then at the clutch switch, finally at the solonoid. The seat switch usually only kills the ignition if you have the PTO engaged, and you leave the seat.
Jul 26, 2010 | Craftsman Garden
Tractor stalls when letting out clutch
Sounds like the clutch safety switch is going bad.
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor stalls when engaging the clutch/brake
There is a safety switch on the clutch pedal, that's not the problem
look at the seat safety switch .
Feb 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor stalling
check wires on switch under seat
Oct 11, 2008 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
54 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
