I have a TCL TV and it has already been set up initially 2 years ago however has not been in use for months. Now when I have plugged in the power cord and antenna it says I need to scan channels and I can't find how to do that. I have tried to manually add channels but it finds no channels. I have tried changing inputs but nothing is working so far.
    Top Expert:
  • Televison & ... Master
  • 48,486 Answers
Setup main menu autoscan
Posted on Mar 28, 2015
  • Anonymous Mar 28, 2015
    Thanks for the suggestion... I did try that but figured it out. The antenna was plugged into the wrong connection. My housemate plugged it into a foxtel wall socket :/.
  • ray gallant Mar 28, 2015
    OK THEN GL
thecritter
  • 29 Answers
SOURCE: I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
Posted on Mar 17, 2008
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
emissionwiz
  • 77499 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
  • 210 Answers
SOURCE: lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Posted on Dec 12, 2009
Testimonial: "Your response was quick pointed me in the right direction I might need help with ID of components to continue"
fuckyoupenis
SOURCE: Can't get anything over antenna
need help to hack and get good signal on my TV antenna
Posted on Jan 23, 2010
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My LG 42LV4400 has a red light in the bottom left corner but it will not turn on.
hello!
2 month and already quit? OK: first thing to do is to unplug TV off the power strip or wall outlet. Wait for a few minutes and plug the set back into the power source. Try to turn on the set manually, by touching sensors or buttons on control panel. some TVs have push buttons, some touch sensors. If your TV was set to "auto power on" mode, then don't touch anything after plugging set in. That's the only action you can do to "revive" the set. If you will be able to turn set on manually and "free standing" without any external connections, except power cord, check your remote control unit. 95% of consumers turn on their sets via "clickers". In case of complete failure, you might have month or 10 month left of factory warranty, depend on price you paid. Use it a.s.a.p! If needed. There is no magic button to heal broken circuitry.
Good luck,
Alex.
Feb 19, 2012 | LG 42LC2D 42 in. LCD HDTV
I HAVE A TV SET MODEL TCL-I4175 MY PROBLEM IS WHEN I PLUG THE LINE CORD AND SW ON THE THE PUSH BUTTON THE FUSE ALWAYS BLOWN OUT . THE LAST TIME I HAVE REPAIR MY TV SET AT FIRST I HAVE REPAIR IT AND ITS ...
I am not familiar with this make but normally the cause of line stage transistors blowing is either power supply faults, line transformer issues or tuning capacitors including flyback diode issues.
Jun 23, 2017 | Televison & Video
My panasonic Th50pz85u will not turn on. I can hear a click and the red light next to the on-off switch flashes twice and continues this flashing twice sequence. When this first started a month ago I could...
U know basic electronic?Can u do basic soldering?U have tools like a soldering iron,desoldering pump or desoldering braids,solders?The power supply board have parts that call capacitors,it dying,that why is causing this problems.The power supply board,that the board,where the power a/c cord plug into it.These capacitors on power supply board it dying,will bulges up on it tops or puffing up on it tops.These dying capacitors are now dead,must be replaced to solved this flashing twice problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 18, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Printer is showing "error: 0xf0af0001 Reset Power". I have unplugged and then plugged in printer multiple times and printer comes ok for about 30 seconds and then the same error message appears will all...
last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Jun 24, 2010 | HP Officejet 5610 All-In-One InkJet...
The power cord hard to unplug from back of tv for wall mounting job
step-1.
first switch off your tv unit and if possible switch off yuor main switch also
step-2.and pull out the plug bu holding the hand inth end of plug not in wire .
still you have the problem
follow step-1. and using wd 40 liqiud (available all electronic shops ) apply between wall socket and juntion of plug
and wait for five minites
then try step-2.
finaly remove wall socket and try it now and remove the plug.
Oct 26, 2008 | Electronics - Others
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Sanyo vizon dp42746 problem
Anyone have a suggestion for this? This thing is a year old and is kaput.... anything????
Oct 01, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
