Question about Refrigerators
Icemaker works but my control panel. Doesn't.
  • 2,963 Answers
Try one of the online appliance parts stores, they are usually quite helpful.
Posted on Mar 28, 2015
Kitchenaid icemaker
Hi, you need to provide more details. Does the icemaker power on when its put on and doesnt make ice or it doesnt power on at all? More info is needed pls
May 05, 2013 | Kitchen Appliances - Others
First icemaker stopped making ice. repairman replaced whole icemaker. Still didn't work. now whole frig doesn't work. Motor is on but no cold air to both sides
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 09, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Icemaker still works but water dispenser doesn't
There's a manifold valve assembly on the back lower side behind the access panel. Replace the manifold, and you should be good.
Aug 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Icemaker doesn't work....It doesn't fill with water???
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Jun 22, 2011 | KitchenAid Architect 25.3 Cu. Ft....
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
Maytag bottom mount freezer (top) icemaker not working
check to make sure that your fill tube is not blocked with frozen water.
if there is no restriction then you have a faulty ice maker.
Apr 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
