Question about Miscellaneous
I have a Suzuki gv7 the lock on the drivers seat broke, i had a pull wire that let me get the seat off but it got stuck under the seat and now i cant get the drivers seat off, what can i do?
    Top Expert:
  • Miscellaneous Master
  • 52,123 Answers
Carry it to a dealer
Posted on Mar 28, 2015
  • Anonymous Mar 28, 2015
    Ok i know that i was seeing if there was something i could do before thst
emissionwiz
  • 80420 Answers
SOURCE: Drivers seat in Suzuki Vitara 2006
You will have to de-trim the seat back to access the mechanism.
Posted on Sep 02, 2008
SOURCE: driver side power seat front to back motor stuck forward
Take apart the drive box in front of seat track, on both sides with an allen wrench. You can then push the seat to get at the bolts to remove it. My trolley drive motor had bad brushes. I am now looking to replace the motor, if I can find the replacement.
Posted on May 04, 2009
  • 3911 Answers
SOURCE: Broken seat adjustment wire under driver's seat...
On the 90s S models there were two screws holding the rails in front and two in back. remove those bolts, disconnect the battery and then the seat belt light wiring plug and the thing should come right out.
Posted on Nov 25, 2010
Testimonial: "Thanks! I had not considered having to disconnect the battery before unplugging the wire under the seat. Very insightful and helpful!"
  • 973 Answers
SOURCE: the seat belt on the
Usually when that happens the Seat Belt Assembly need to be replaced, they are Non-Servicable, meaning that there are no internal replacement parts that can be replaced or fixed.
Posted on Jan 25, 2011
ghost4548
  • 776 Answers
SOURCE: I own a 2004 hyundai
Go to www.hmaservice.com and register your vehicle by VIN #..
you'll then have access to wiring diagrams, shop manuals,
service bulletins, illustrations, etc.
Posted on Jun 29, 2011
Driver's car seat back will not lock in upright position
Mechanism most likely broken . I had a Hyundai and was rear ended and the mechanism broke plus I know of several other seat backs that broke on people
Jun 06, 2016 | 2009 Honda Accord
My 2010 Avalanche driver heated seat won't warm up. Lights come on but no heat. Pass side works OK Any ideas?
ck to see if the wires are still connected to the heater under the seat itself , maybe you stuck something under there and broke a wire ,
Mar 19, 2015 | 2010 Chevrolet Avalanche
My front drivers side seat wont move forward or backwards. seat stuck close to steering wheel
need to check under the seat or even remove the seat if you cant see the problem. there is a wire that breaks connecting the two rail releases. find the wire and reconnect it
Feb 12, 2015 | 2000 Hyundai Elantra
How to lift the seat
Dont know which model suzuki you have, but if its a GSXR with a split seat, I believe the lock for the seat is on the left side just under the passanger seat. Insert key and turn it to un-lock. While holding the key in the un-lock position, lift up the drivers seat where it splits from the passanger seat. from there, you can remove the passanger seat. Most other models you turn and hold the key in the un-lock position and lift up the back of the seat. On older modles, you turn the key and lift the seat from the side.
I hope this helps..
Jan 05, 2011 | Suzuki RV 125 VanVan Motorcycles
How do you remove the stock rear fender to install a rear seat?
Look under the "typical driver side" right above the chain, under the rear cowl cover there is a key lock. Use the key for the ignition to unlock that lock, as you unlock it pull up on the cowl cover and it will slide right off, if you have the rear pillion"back seat", then you will just pop it right on. And it will be the same procedure to remove and replace that if you want to.
Nov 11, 2010 | 1998 Suzuki GSX-R 600
Driver's seat that won't lock
seat is held in with 4 bolts. at least 1 electriocal connecter ( 2 if heated). take off headrest, pull the seat and see what's broke/stuck. shouldn't take too long
Dec 08, 2009 | 2003 Volkswagen Beetle TDI
My drivers side seat belt is locked up in the car and cannot be pulled out to wear it, have you heard of this happening with other suzukis?
Yes, the safety lever on the roller is stuck, remove the roller, clean, lubricate with vasaline and refit.
Nov 19, 2009 | 1999 Suzuki Vitara
The front driver seat on 2004 Camry is stuck
Perhaps an item got caught under the seat and possibly affected the linkage wire between rail tracks.A small linkage wire trips the console side track.Without this,that particular track will not disengage.Look under the good working passenger side seat and you might notice this linkage wire.It will then give you an opportunity to see if it works well on the inop seat. You can pull that wire(or trip that linkage arm by hand if you are in a dilemma and need the seat moved in order to drive but use caution on these moving parts and dont get pinched.
Jul 27, 2009 | 1992 Toyota Camry V6
Driver seat not moving back and forth
under the seat is a thin wire that goes from one side to the other it has most likely broke you need to find the secondary lock it was connected to and release it to move the seat but you must also release the main lock so i suggest replacing the wire . THIS IS FOR MANUEL SEATS
now as for power seats you will have to locate the power lead wire and make sure it is not broke if so you can replace the connecter with an aftermarket one and it may work again
May 15, 2009 | 2004 Honda Accord
Miscellaneous Logo
Top Miscellaneous Experts
Brett
Level 1 Expert
Valmae Patterson
Level 1 Expert
cwcollectr
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
