My electric saladxpress WST2020 wont turn on and I have followed all the instructions carefully. Do you have any idea what might be wrong? I've only used it once.
3 Suggested Answers
STR8JCKTED
  • 42 Answers
SOURCE: razr and bluetooth
IN SETTING GO TO BLUETOOTH AND ENABLE IT THEN TRY
GOOD DAY
KZ
Posted on Feb 25, 2008
  • 21 Answers
SOURCE: Why does the 4th thread keeps breaking on my
Most likely it is either your tension on thay thread being too high, or the needle is too big for the project you are working. Lower that tension, use the next size up needle, and thay should fix it. Also, I STRONGLY suggest only using maxi-locks thread. They are more expensive than other serger threads, but they are always half-price at hancock... Any other thread I have tried using causes breakage, especially on the the lower looper (the 4th thread). Although, of you keep the tension low-below 3 or so, you should be ok. If these tips don't help, I would also check your cutting width, if your machine has an adjustable one. If it is leaving too much gabric to the right of the needles, out is conceivable that this is putting too much pressure on the threads. Let me know if this helps!
Posted on Jun 23, 2011
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
Putting the base together
When i put my Fieldcrest Armoire together the base connected fairly easily to the other 3 pieces. Are you sure that you followed the instructions very carefully and haven't mistakenly mixed up some of the wooden pieces? I would re-read the instruction manual very carefully again and if you are sure you've followed the correct steps, you can contact the place where you bought it as maybe they gave you a wrong piece. Good luck.
Sep 29, 2012 | Foremost Fieldcrest Armoire - Espresso
Been spluttering on start up at any time and weather conditions. now it wont start at all,it is turning over ok and had used it 1 hour before it wouldn't start.i've checked the plugs/leads and...
If you've ruled out all electrical issues (i.e checking all fuses, relays and for spark) then the problem will be fuel or air related. Either air isnt getting into the intake due to a blockage, esp @ any idle speed control devices. To check if thats the issue depress the throttle half way whilst cranking. If that doesnt do it then you're looking at a fuel issue, including lack of pressure comming from the pump, blocked injectors or a kinked line. To check if there is fuel pressure find the fuel line quick coupling and using a rag carefully undo. If there is pressure it may finally be the crankangle sensor which allows the fuel pump to continue pumping. Checking that requires an oscilloscope (auto electricians tool).
Sep 18, 2011 | 1998 Honda Odyssey
I entered my pin in wrong and it asked for my puk, i lost that stuff a long time ago. i tried turning it off nd back on bt now it wont go 'home' until i've entered my puk. i've tried...
These directions are for an AT and T phone, but other than that would be the same for any carrier.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card.
You can obtain your phone's PUK code from your carrier in one of these ways:
Log in to Your account.online
Use a Technical Support Chat
Contact your carriers Customer Care
Get Your Phone's PUK Code Online
Go to the Phone/Device page.
From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Sep 18, 2011 | Teac (DV-W58GA-PUK) Burner
Dryer won't turn on at all.. There is power to it because it shocked me and the washer runs. Do you have any idea what might be wrong?
Wait a minute, the dryer shocked you? I've seen this happen twice, where I got shocked and the dryer welded itself to the washer. Ok, you may have a electrical issue with house wiring. Or, someone may have wired the dryer cord incorrectly to the dryer. I've seen both. I would address the "shocking" issue and once it's solved it most likely will fix the Dryer operation.
Oct 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Oven wont turn on due to auto mode.Cannot cancel auto mode.
If you have followed instructions properly, and cannot get it off auto. then you will need a new timer, alternatively, the timer can be bypassed
Dec 07, 2008 | Ovens
Razr and bluetooth
GOOD DAY
KZ
Aug 21, 2007 | Motorola Mobility RAZR V3
Help stressing out
If you manage somehow to access your player through the computer, run a firmware upgrade. Get the firmware + instructions here - http://www.sandisk.com/Retail/Default.aspx?CatID=1301 Take care to follow the instructions.
Jun 18, 2006 | SanDisk SDMX1 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
