Question about Husqvarna Lawn Tractor  25 HP 54in Deck Model YTH2454
Transmission does not run forward or backwards, machine starts and blades turn good but mower does not move
    Sergeant:
  • Husqvarna Expert
  • 187 Answers
For an answer dealing specifically with your machine include this information with your post. Make/Model/Year/Engine Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
If this is your mower, Husqvarna Lawn Tractor 25 HP 54in Deck Model YTH2454, it was last manufactured in 2009. The YTH2454 was manufactured in 2007, 2008 and 2009. You don't say how many hours are on the machine. This is likely important.
I assume you know about the transmission unlock lever at the back of the machine. When that lever is pulled out, the fluid in the transmission is cycled through a bypass port and does not power the machine. The same thing happens when you lock down the clutch/brake pedal. Assuming the levers and connections are in good shape and operating as the are intended and assuming you know these two items are in the proper position then we should move on and check the next two items. Belts and pulleys.
Your transmission is driven by a belt going around a pulley on the engine shaft, back through a tension device (which has two smaller pulleys) and then around a pulley on the top of the transmission. This belt and these for pulleys must be in good shape and should be spinning whenever the engine is running. Check the pulley on the transmission and be sure is hasn't stripped out the spines on the shaft. Some times the tension pulleys wear out and freeze up. Sometimes the belts get out of the groove.
If all of this looks like it is working, then the problem is in the transmission. What follows next is my standard Hydraulic Transmission post.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: Hydro Gear parts Hydro Gear transmission Parts Diagrams and Serice Repair...
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, the Huskvarnas and most all others, are serviceable. A complete line of rebuild/replacement parts for JD's can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process. https://www.tufftorqservices.com/instance1EnvEELogin/html/login.html
Posted on Mar 28, 2015
  • Husqvarna Master
  • 2,027 Answers
Do have a broken belt?
If the pulleys turn but the tractor does not move before you go farther see if you have a broken shear pin in one of the pulleys You may have a transmission that needs work. if that doesn't work out.
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Mower barely moves forward or backwards with or without the blades turning,engine runs fine but can't seem to get mower to move
Well you have a fault with the belt which goes from the engine to the transmission being too loose or the transmission itself has failed. Get underneath it and, with the engine cold and not running, grab hold of the belt and see if there is any slack in it. This would be the topmost belt, it should not have any slack in it unless the clutch pedal is pressed down. Don't try this with the engine running unless you have an extra set of fingers and a surgeon at hand. If the belt is good then your transmission has failed and you need another mower as the cost of the transmission will exceed the value of the mower. There are mower boneyards around and used trannys for sale on ebay, but most likely you will be looking for another mower.
Aug 01, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Lawn Tractor  25 HP 54in Deck Model YTH2454 Logo
356 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
