Question about Culligan Tools & Hardware - Others
My Culligan AC-30 RO system, original owner installed in 2000, started leaking to the drain last night.
It is very faint but noticable trickle you can hear when you are near the sink. When I turn off the water the trickle goes away. I don't have the airgap shown in the newer manuals. I have a line going from the filter manifold to my sink drain. Ideas?
  • Culligan Master
  • 2,963 Answers
I believe as vague memory recalls their is a back wash or bypass of the ro filter system. Is the leak to the drain from a tube? or from the unit? IF you have a pump, the pressures are high entering the ro filter. If no pump they are no more than the city water. But given the age, plastic parts may be approaching their end of life. I Don't know what that is, but you might google this model and see if anyone is having these kind of problems.
Posted on Mar 28, 2015
  • epaiken Mar 28, 2015
    G, No pump just line pressure from curb. There is a small reserve tank but it has a separate line from the manifold. And yes, there is a line from the mainfold straight to my sink drain. None of the Culligan manuals I've been able to find are installation only, no troubleshooting ideas. I tried several search engines but most folks are experiencing leaks from thier connectors or filter housings. This one seems to be internal. If no one has any ideas I may just look at taking apart and see what the insides look like.
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
I have an AC 30 and it does not appear that the local culligan dealer installed the flush line correctly as per the diagram in the owners manual. It shows the flush line coming off of the faucet assembly...
The flush rate is dependent on the Membrane used (IE: 16gpd, 35gpd, 50gallons per day), the TDS of the water, the amount of water used daily from the RO and the size of the storage tank. When the RO is creating water (depending on TDS) you will waste about 3 gallons for every gallon of product water. If the system is under the sink and drains directly to the DWV line then yes the drain should be run through the AIR GAP faucet to prevent cross contamination of the RO system.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
My undersink RO system leaks at all four tube connections on the manifold. I inspected the fittings and the o rings are fine. I inspected the tubes and I cut off the ends of each piece to make sure that...
The quick connect fittings need to be fully seated or when pressure is applied they will leak. If the feed is pressure is high to the RO I have seen this occur also. JG John Guest makes a small locking clip that goes on these fittings to hold them tight. Here is a link to JG which shows this application.
http://www.johnguest.com/Home/applications/beverages-and-drinks-dispense/Inch-Size-Accessories/LOCKING-CLIP.aspx
RJ
Sep 05, 2010 | Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
I need a water diagram for a culligan water system serial number is AC10001293
Here is a link to the Culligan website for the AC 30 owners manual. It has a breakdown view of the RO.
http://www.eculligan.com/support/ac30_owners_guide.PDF
This is about as close as you will get to a water diagram for the RO. The only place to find a flow diagram is in a service manual and those are well protected by Culligan.
RJ
Jun 19, 2010 | Culligan Under Sink Water Filter
Water has been trickling to the drain for at least a couple of hours now, maybe longer. I just noticed it this morning. It's currently in regular run mode and not in regen mode. I put the valve to...
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
May 15, 2010 | Culligan Sediment Water Filter
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
http://www.freshwatersystems.com/support/AC-30.pdf
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
I have a Culligan water softener and noticed recently that there is a running water sound coming from the drain tube. There is no leaking, and the sound is almost like a constant trickle. It stops if we...
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Jul 12, 2009 | Culligan Sediment Water Filter
Culligan AC-30 R/O filter change
Please see the below link for a pdf file and it should explain the procudure for filter changes for the Culligan AC-30 RO Water System
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Feb 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Tools & Hardware - Others Logo
135 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Dan Connors
Dan Connors
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
