Question about Roper Washing Machines
How to fix broken washer
The drum moves around a lot and doesn't spin very fast
  • Roper Master
  • 5,323 Answers
Loose clutch assembly or loose worn belt if belt driven
Posted on Mar 29, 2015
  • 163 Answers
SOURCE: object between drum and spin basket
yes there is but you have to brake apart the hole machine and thats not ease I strongly recomend a tech and pay for this..good luck
Posted on Jul 27, 2006
  • 13 Answers
SOURCE: Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Posted on Feb 02, 2007
JULIANFIX
  • 975 Answers
SOURCE: No longer rinses or fast spins...although drum does go round slowly...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Posted on May 05, 2008
the_admiral6
  • 14 Answers
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Posted on Mar 07, 2009
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
When spinning drum is slamming against washers sides. Can this be fixed
This would be an out of balance issue. Level your machine first and then make sure you load it evenly when adding clothes.
Apr 05, 2016 | Washing Machines
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
Whirlpool design 2000 is imbalanced eery load - moves around violently, makes pounding noises.
Thanks for choosing FixYa and welcome. You need to check the suspension of the washer and make sure everything is intact. Now, if the washer is thumping during spinning, this is probably the motor drive or the spin bearing. This would cause a lot of noise. Your washer will act up if it is not balanced right. Check the floor and make sure it is level. If that checks out, look into the motor drive and bearings. The motor drive controls the spinning.
Apr 28, 2011 | Whirlpool Washing Machines
I have a kenmore front load washer model 41744042400 the drum seems to be off its track. it makes a lot of noise when spinning and shakes a lot. One of the shock absorters was broken and i replaced it....
they dont have tracks they sought of float in the middle of the tub held on by the shaft coming off the spider arm on the back of your drum, if you can move the drum back and forth and it makes a metal crunchy kinda noise your spider arm has snapped to fix it you need a new drum and will almost quite literally have to dissasemble the machine into every piece its made of, altho not neccesarily difficult is quite time cosuming about 3-4 hours (thats for someone with experience)
Sep 20, 2010 | Kenmore Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My washer makes loud noise during the spin cycle. I think the drum is off center. How do i fix it?
try moving the cloths around to even the load out my washer does this alot.
Nov 25, 2009 | Washing Machines
Knocking sound
The spider on the back of the drum is most likely broken. The part should have a 10 year warranty. Labor should run 250 - 350, unless you call A&E, then it will be a lot more.
Jan 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
