Question about Nakamichi Audio Players & Recorders
Where can I get a pickup motor for a Nakamichi 680 ZX Tape Deck
  • Nakamichi Master
  • 1,267 Answers
If you need a cam motor, they can be found but mounting might have to be modified. The best way to get an answer is to connect with those Technician who used to work for the company in the past. On Tapeheads dot net the user name Nakdoc or Perry would be the best people to deal with in this case. They are both Technicians who could fix it for you as well as get it going in the best of condition.
Posted on Apr 02, 2015
5 Suggested Answers
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette Deck
Check leaf switches and also, press play -- after a few minutes, feel motor(s) for heat build up. If it gets hot, either motor is bad of something is preventing it from rotating
Posted on Apr 25, 2008
  • 319 Answers
SOURCE: Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Posted on Aug 03, 2008
  • 61 Answers
SOURCE: Replacement motor
You can identify rotation direction of the motor and order one from this site
http://www.studiosoundelectronics.com/cassette.htm
Posted on Sep 28, 2011
skywavebe
  • 1267 Answers
SOURCE: the motor tape deck nakamichi speed up after a while in operating
Your capstan motor may be so badly worn that it is time for a new motor. Motors that are old and worn usually do speed up until the brushes break inside and the motor just stops. You do not state the model but there are guys that still work on them.
Posted on Dec 06, 2012
Hi NAKAMICHI, I'm looking for a head cassette deck type DR8 where I can get ..thanks NAKAMICHI
Check ebay every few days and this web site - http://mobile.audioproz.com/AP.php?Prod=Cass_Parts&Pg=18&Sort_By=Model&Sort_Order=ASC
Jul 27, 2016 | Nakamichi Audio Players & Recorders
Nakamichi cassette deck one. i bought new motor for this deck because the old one was surging (checked the voltage for fluctuation 1st to make sure it wasnt a pre-motor problem). installed it and the new...
There will be either a hole in the top of the motor with a speed adjusting preset. Or there will be one on the printed circuit board. New Motors don't come set up. You have to adjust them for each deck. You will need a small screwdriver to adjust. You will have to figure out by ear when the speed is right.
Feb 23, 2014 | Audio Players & Recorders
Nakamichi BX 300 tape deck runs slow in play,belts and idler have been replaced
There is an adjustment in the motor that sets the speed however you need to have a frequency counter and speed alignment tape to adjust the speed correctly. There was also suppose to be oiling of the mechansm at the time the belts were put on.
Jan 05, 2013 | Audio Players & Recorders
The motor tape deck nakamichi speed up after a while in operating
Dec 02, 2012 | Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Our Nakamichi CD player has frozen up on us. Our Nakamichi Cassette Deck door won't close and prior to that it tangled a cassette tape and quit working. Both were purchased in 1991 along with a...
The CD player muigt be able to rescue by a reset top factory settings, mostly available in your manual, the cassette deck i think needs to be repaired.
Aug 05, 2008 | Nakamichi CD-35z CD Changer
Aug 03, 2008 | Audio Players & Recorders
Apr 23, 2008 | Audio Players & Recorders
Tape deck not working
Sounds like a motor problem. Try turning the motor by hand to see if it's bound up.
Geno
Feb 27, 2008 | Audio Players & Recorders
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
237 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
