Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Does not matter whether I use gentle cycle or normal wash cycle business shirts sleeves are all really badly tangled together when cycle has finished. Really puts bad creases into shirts?
  • 3,287 Answers
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Posted on Mar 28, 2015
I just bought a defy top loader dtl 151 and it keeps tangling the clothes
Here are a few suggestions.
Sometimes too much water ( or not enough clothes) will result in tangled clothes.
Sometimes the types of clothes will tangle more easily than others.
( Thin cotton tee shirts or long cotton dresses might tangle easily. )
I might recommend you mix in some heavier and thicker items to help, such as towels or blue-jeans and see if that fixes the problem.
God bless your efforts.
Aug 22, 2016 | Washing Machines
I got a new heavy black Tee-shirt. I wanted to pre wash in case of 'bleeding'. No matter what cycle I choose, the spin was very slow, resulting in wet shirt. Why?
I am kind of going out on a limb here but I think you may have an unbalanced load which would affect the extraction stage. Have you selected the smallest load size and normal cycle?
Aug 04, 2016 | Haier Washing Machines
I have a Samsung washer front loader it vibrates really bad when it is on spin cycle model #wf409anw/xaa
To test whether the problem is caused by a fault in the machine, or the way it's being used, run it through a complete empty cycle. No clothes, no detergent.
If it still vibrates under those conditions, call a repairman. If not, then the cause is an unbalanced load. This often happens when dis-similar weight articles are placed in the washer at the same time - such as bath towels along with tee shirts, etc.
Dec 12, 2014 | Samsung Washing Machines
All my shirts are ending up with fuzz balls . Is there a lint filter?? i can't seem to find it .
There is no lint filter. Make sure you have enough water to float the clothes. Try washing your shirts with the permanent press or gentle cycle.
Nov 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Tiny holes in the front of my t-shirts...
wow- my husband and kids were blaming me for putting holes in their shirts with bleach- tried to explain to them that i did nt use bleachon dk colors- will changing the tub help?
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes come out tangled
Things tend to intertwine in the washer, even more so in front loaders. The only things that I have found that help is to use fabric softener, a gentler cycle, and an extra rinse. This alleviates the problem some for me, but it doesn't really go away entirely.
Regards, --W/D--
Aug 01, 2009 | Kenmore Washing Machines
My cloths don't come clean.....whites are dingy even with bleach. Normal stains on regular colors don't come out. If you put more than one pair of pants or two long sleeved shirts in a load they come out...
First I would start by cleaning your washer system with vinegar. Ran your machine like you would without clothes and pour a cup of vinegar like you would with the soap for a whole cycle. If this doesn't work chances are your drain is clog or your pump isn't working properly.
Jun 04, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Fabric pulls on gentle cycle
Check the inside of the drum to see if there is any loose vanes.  Then check the holes in the drum itself to see if there is any protruding metal shavings that is causing the problem.  There should be no rough edges at all.  It sounds like the drum is the problem.
Apr 15, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
