Question about Dryers
Panel lights up but fan doesnt turn - Dryers
    Genius:
  • 1,617 Answers
What is the Panel?? make/model of fan?
Posted on Mar 28, 2015
I have a 2400 monitor heater-after being on awhile it starts beeping,and wont go off until i turn it off-but wheres the heat
dust build up at the heat sink fan area.Open the side panel. blow lightly with compressed air NO air? blow through a soda straw, keep it dry
Aug 13, 2014 | Computers & Internet
Samsung 50 inch DLP
Most Dlp sets have a fan for cooling the bulb this should start at switch on if it doesnt bulb will not light.
Check fan is pluged in & that blades can turn freely.
Oct 11, 2007 | Samsung (LTR268W) Television
It was working then suddenly turn off and now when i try to turn it on it doesnt lasts 3 seconds and turnes off agaiin,the red light blinks 7 times
The error that you are receiving is a "Panel Temp Error". If you are attempting to fix it yourself then check that the fans in the tv are not clogged and can spin freely.
Good Luck.
Rich Lilja
Sep 30, 2013 | Sony KDL40EX500 40 in. HD-Ready TV
Electric fan does not work
This can be due to a bad relay or coolant sensor that turns on the fan or a bad fan, a good test to do to see if the relay and the fan work is to start the engine and then turn on the ac, if the ac doesnt work then unplug the coolant temp sensor this will turn on the check engine light but it will reset when you restart engine, if the fan turns on then fan and relay are good and its the sensor, if the fan doesnt run then it may be the relay or fan, a quick test of the fan is to dissconnect plug to fan and run a power and ground wire to fan and if it runs then you have a bad relay,hope this helps,e0be4e7.gif
Oct 24, 2010 | 1991 Buick Century
Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Jun 07, 2010 | Hitachi P50H401 50 in. Plasma HDTV
GE Profile Microwave - JVM2070SK02 - when turning on the underhood light there was a bright flash/pop - both underhood and interior lights are out - carosel doesn't turn - fan sounds labored - control...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 13, 2009 | GE Microwave Ovens
KDF60XBR950 doesnt turn on....fan is on just flashes green
There is no less than two Cooling Fans on the right side. Either one of them could cause the problem. The one that turns slow or stops turning quickly is the one that is probably causing the problem.
I hope this helps,
Sky Assoc
Sep 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Won't Print But Ready Light On Fan nonstop
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Apr 04, 2008 | Brother HL-2040 Laser Printer
Dryers Logo
48 people viewed this question
Top Dryers Experts
