Question about Philips 47PFL3603D/F7 LCD HDTV, 47 Diagonal Size, 1920 x 1080 Resolution, 1080p FullHD Display Format, 16:9 Image Aspect Ratio, 29000:1 Dynamic Contrast Ratio, 500 cd/m2 Brightness- cd/m2, 178 degrees Viewing Angle, 5 ms Pixel Response Time, 3D digital Comb
The TV started smoking. Thought it might be dust. doesn't appear to be.
Plugged it back in and it started smoking again and smoke moved from LH side vent to middle and RH side vents.... Any idea what is happening ?
    Top Expert:
  • Philips Master
  • 3,113 Answers
Your tv is burning part of it's electronics. Turn it off and unplug it. Either take it to a repair ship or replace it.
Posted on Mar 28, 2015
2000 elantra white smoke during speed, doesn't start
White smoke normally indicates steam, did the car overheat ????...if it overheated check hoses for leaks,,,, loss of water etc
Jun 13, 2013 | 2000 Hyundai Elantra GLS
My truck is blowing white smoke out the tail pipe and I have no power wont go but I can idle around its a 2055 f250 turbo diesel, 300000 kms...litterally just started doing this a couple days ago..now ...
White smoke for a diesel means air in the fuel system. You will have to start at the engine, I start at the line going to the fuel pump. Get some fuel in a can, remove the line to the supply side of the pump and put another line from the can to the pump. If it starts and doesn't smoke , then you have to work your way back to the tank and find the spot that is sucking air. If it doesn't start the I would replace the filter first, check again. There is a possibility that the injector pump is bad, but these don't usually throw white smoke. They just make the engine have very little power or no start.
Sep 21, 2011 | 2004 Ford F250
Remote Not Working etc.
If you have no idea what you're doing, NEVER open up a TV, especially if you're planning on SOLDERING!
Even after it's been unplugged for several hours, if you touch it in the wrong place you will be knocked on your ***!!!
If you know nothing about TV's you wouldn't know even where to start looking once you opened it up.
Most likely what happened is an accumulation of dust in an high voltage area of the TV was shorting something out, and when you moved it around and tipped it up, some of that dust moved. In particular if someone smokes in the room with the TV, the dust tends to cling more and conduct more.
Sep 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Flyback shorted, trying to replace
astimagnetic.com:flybacks.video heads,laser pickup and more...
Jul 08, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
Started smoking and fan is still running but not cooling. neither
You have a bad compressor that is the only thing that will make something smoke and not let anything stay cool
Feb 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lg tv type PT-48A80T
a defective product , bring it back to the store and swap it for a good one
Nov 27, 2008 | LG 42LC2D 42 in. LCD HDTV
Focus/Screen block bad
This part is called the Focus Block and has 6 controls, 3 for focus and 3 for screen. The screen is the overall brightness of the CRT and the focus is the sharpness. The part can be ordered by description from any RCA parts distributor but the controls should be set by someone with experience.
Jun 26, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Phillips magnavox smokes
Replace the bad cap:
Capacitor C506 = 680pF 2kv = 483512247584 part number
Buy at tritronics by credit card: 800-638-3328
Oct 24, 2006 | Philips Magnavox 27MS343S 27" TV
Phillips tv smokes
Im sorry I do not have a schematic on this set, now the RCA I do that is under the heading. If you get a schematic from http://www.servicemanuals.net and send me a copy I will be more then happy to assist you with this repair.
Oct 23, 2006 | RCA 32F531T 32" TV
Philips 47PFL3603D/F7 LCD HDTV, 47 Diagonal Size, 1920 x 1080 Resolution, 1080p FullHD Display Format, 16:9 Image Aspect Ratio, 29000:1 Dynamic Contrast Ratio, 500 cd/m2 Brightness- cd/m2, 178 degrees Viewing Angle, 5 ms Pixel Response Time, 3D digital Comb  Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
