Question about Canon MP560 All-In-One InkJet Printer
SMALL BLCK TANK AND BLUR TANK WON'T CLICK INTO PLACE.THEY WILL CLICK INTO OTHER SPACES SO I DON'T THINK IT'S THE TANK.ANY IDEAS
    Problem Solver:
  • 16 Answers
  1. I don't know but call Canon 877-287-7032 you will get a person who will tell you what to do. Try it and get running quick..they are good.
Posted on Mar 28, 2015
Tip
Blur "is not a valid 32 application" fix....
I just have upgrade my window (install new window 7 ultimate) and I can't play Blur anymore, It says that "Blur is not valid a 32 application", even I reinstall and activate Blur again but It still don't allow me to launch the game, any help please !!!!
on Aug 19, 2013 | Activision Blur
It says email address can't have any spaces which it don't
check the first space before the b in betty for a space usually the space is so small you wouldnt recognize it if this happens again us the backspace button untill the curser is does not move then try once more
Feb 04, 2013 | Facebook Social Network
Severe vibration from engine
If it makes the mirror blur without driving the wheels, then I would say main bearing issues.
Jun 08, 2017 | 1998 Ford Explorer
Bad gas need to drain the tank of a 2000 montana
There's no drain on the bottom of the tank on these, and the fuel pump and level sensor assembly is a real ****** to reinstall because of the way the o-ring is designed. It sounds like there's a good chance you've got water in the tank, though, and you want to get that out of there pronto; there are various steel lines and such which will corrode and start shedding rust flakes if you don't. If the tank is full, this is not really practical to attempt without a transmission jack, so you'll need to siphon the gas out first. Get a replacement fuel pump module o-ring FROM THE DEALER to make the reinstall easier, even if you are replacing the pump. Dropping the tank when it's nearly empty is no big deal; any of the repair manuals can step you through that. You won't get all of the water (and other crud, if there is any) out of the tank without doing this, though. When you reinstall the pump module, use some grease or vaseline to stick the o-ring into place on the tank, and then get a helper to hold the flange of the module up against the inside of the retainer collar while you get the collar started onto the threads and tighten it down. This will give you the best chance of getting the o-ring to stay in place, in my experience. If the o-ring is just a trifle small and won't slip down into the groove on the tank, stretch it a bit and it should be more cooperative. The aftermarket ones tend to be a bit too big, and there's not much you can do to get them to work.
Nov 24, 2011 | 2000 Pontiac Montana
My '99 wagon spare tire boot gets an inch of water in it after rains. The compartment holding the tire jack also fils up, and the small floor area behind the drivers side rear wheel well also getrs...
What is the make of your wagon? Regardless you shouldn't be drilling holes anywhere. Check your rear window seal, tailgate or lift gate seals.
Apr 10, 2017 | 1999 Ford Escort
My hoover rug clearner won't pick up water when I pull back.
You don't say which model you have but this often occurs on the F5000 series. The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jul 26, 2011 | Vacuums
Hi, My Toshiba TV won't come on - it has a pixelated blur in the corner of the screen. Any ideas?
hi im having exactly the same problem with toshiba 40bv700b
eont come off standby tv only few weeks old
Jul 09, 2011 | Toshiba Televison & Video
Saeco Odea Giro alarm light on all the time and temp light off
Make sure everything is fitted in place, there are several sensors that can bring the lamp to light. I have not heard that the water sensor is gone on Odea machine.
Can the machine run the selftest and can you see any water come out?
Jul 13, 2008 | Saeco Odea Giro Espresso Maker -...
Canon MP560 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
